Author Topic: Dented Capacitor... Would you use it?  (Read 4455 times)
M250R201SA
JGriff021985 JMG717
Dented Capacitor... Would you use it? « on: August 29, 2015, 07:42:27 PM » Author: M250R201SA
I have a GE Capacitor that was never installed, but sloppily packed and has quite a few dents in it.  Would anybody use this, or throw it in yesterday's trash?  What would happen if I were to use this?  It looks different than the capacitor that came in my new GE M250R2, which, btw, works great, so I have no intent or incentive to replace it.  Just wondering what would happen if I were to use a dented capacitor if I were to build a 250 watt conversion?
Re: Dented Capacitor... Would you use it? « Reply #1 on: August 29, 2015, 07:43:54 PM » Author: Solanaceae
I would not use it, as the dents may have broken the layers between the roll of foil, shorting or damaging it.
Re: Dented Capacitor... Would you use it? « Reply #2 on: August 29, 2015, 08:18:17 PM » Author: Ash
Depends how deep dents are vs how much reliability you want from the system. The demand for reliability from a personal collection lantern is not very high, since for you the cost of replacing a failed capacitor is only the cost of capacitor itself, and no production/etc is stopped by the failure
Picture ?
hannahs lights
Re: Dented Capacitor... Would you use it? « Reply #3 on: August 31, 2015, 04:34:42 PM » Author: hannahs lights
If I was you I would try the cap with a multimeter it should show a gradually increasing DC resistance if it does its probably OK. Next step try it on mains just to make sure there's no shorts
M250R201SA
JGriff021985 JMG717
Re: Dented Capacitor... Would you use it? « Reply #4 on: September 20, 2015, 08:32:56 PM » Author: M250R201SA
Picture ?
I will try to take a pic tomorrow and send it.  I tucked it away, and have to get it back out.  Also, it is worth mentioning that it is a 3rd party GE capacitor (not made for use on the assembly line, but made for the spare parts division)
Re: Dented Capacitor... Would you use it? « Reply #5 on: September 20, 2015, 08:37:08 PM » Author: Ash
As long as it is the correct spec it does not make difference.... Things get bad when inappropriate capacitor type is used such as X2 in series with lamp....
