Author Topic: T8 and T12 in serial connection on 40W choke. is there any problem?  (Read 2549 times)
T8 and T12 in serial connection on 40W choke. is there any problem? « on: August 17, 2015, 08:38:54 AM » Author: Roi_hartmann
So the question is, Is there any harm done using combination of 18W T8 and 20W T12 in 230v 40W choke ballast or will it just work out fine?
Re: T8 and T12 in serial connection on 40W choke. is there any problem? « Reply #1 on: August 17, 2015, 08:42:11 AM » Author: sol
If I remember correctly, I believe I did see such a combination and it seemed to work. I don't recall if I saw it in person in Europe or on the Internet, though. I can't see why it wouldn't work.
Re: T8 and T12 in serial connection on 40W choke. is there any problem? « Reply #2 on: August 17, 2015, 09:04:06 AM » Author: Roi_hartmann
Primarily I was wondering does it have any significant negative effect on lamp life. Ive been running such combination for some days but rarely left such combination to permanent.
I remember someone asked somewhere here this same question years ago but I dont remember what was the answer and did not find it anywhere.
« Last Edit: August 17, 2015, 09:05:42 AM by Roi_hartmann » Logged
Re: T8 and T12 in serial connection on 40W choke. is there any problem? « Reply #3 on: August 17, 2015, 09:10:54 AM » Author: sol
I can't imagine it would have a significant impact on lamp life, but I really don't know. One lamp would likely be slightly overdriven and the other slightly under driven, but I don't suspect it would be enough to have a big impact. Maybe in a large installation where the lamps are used a lot, you would notice that one type burns out faster than the other.
Re: T8 and T12 in serial connection on 40W choke. is there any problem? « Reply #4 on: August 17, 2015, 11:25:34 AM » Author: Ash
It won't be a problem in continuous on mode. Whatever variation in working current would be, it is way below the tolerance of the lamps, and below the difference between running 2 lamps on 36/40 choke vs 1x 18/20
What i would check however is, how blink happy the startup is. That would have effect where lamps are switched on and off more often
"Maybe in a large installation where the lamps are used a lot, you would notice that one type burns out faster than the other."
I think that would result from differences in the quality between the T8 and T12 lamps (as i can imagine, different models & manufacturers), more than anything related to the series connection
Re: T8 and T12 in serial connection on 40W choke. is there any problem? « Reply #5 on: August 17, 2015, 02:58:59 PM » Author: Medved
The T12 will behave like T12's use to do on a series circuit, the T8 will do what T8's use to do.
In other words: Don't worry, no problem related to this combination at all...
