Author Topic: CFL lamps instant start  (Read 10326 times)
form109
Re: CFL lamps instant start « Reply #15 on: December 30, 2008, 08:42:15 PM » Author: form109
evil!!!
arcblue
Re: CFL lamps instant start « Reply #16 on: January 01, 2009, 06:42:06 PM » Author: arcblue
I've always been fascinated as to what may cause a fluorescent lamp to instant start vs. rapid start. I've seen instant start CFL's start with a flicker or in steps like a rapid start on certain occasions, such as when put in base up instead of base down, or just randomly on certain days.
I've also seen linear, magnetic-ballasted fluorescent rapid start & preheat ballast occasionally instant-start a lamp.
All I can guess is that environmental conditions (temperature, humidity) and voltage (slightly high or low line voltage at a particular time, or at what point in the AC cycle the switch is turned on) may effect starting behavior.
I'm lampin...
lightman64
Re: CFL lamps instant start « Reply #17 on: January 24, 2009, 08:17:04 PM » Author: lightman64
i noticed sylvania has programmed/rapid start ballast in all of their cfls. also they make instant start ones too. i always buy slyvania or GE.
