nicksfans
Down with lamp bans!
I don't think I've seen a more "ghetto" retrofit than this. Can't believe it's a commercial product!
My Gallery Instagram YouTube
toomanybulbs
i wonder how many of those leds got their domes trashed? they are exposed and not much care was taken. that fan will be the failure point even before the crappy min wah power supply dies.
BlueHalide
wow, that's terrible. Ive done my share of commercial retrofits, but nothing as jerry-rigged as this. A worm clamp around the halide lampholder to secure that piece of junk LED fitting was the cherry on top for me. Btw those exposed wire nut connections inside the reflector technically wouldn't be to code, and shouldn't pass if ever inspected. Whoever designs this stuff clearly puts no thought into it...garbage.
Also, that installer should've left the original lead on the fixture (unplugged) rather than just cutting it at the ballast box, that way, when that pathetic excuse for a 400w MH equivalent fails (which shouldn't be long), the technician can just remove said failed crap, reinstall MH lamp and plug the fixture back in without having to put a new lead on the MH ballast. I just hate it when I go to convert a formerly MH fixture back to MH from LED (what a concept) and the ballast is either missing or the leads clipped unusably short. Switching a MH, MV, or HPS fixture to LED is like removing the 5.6L V10 engine from a Dodge Viper, an installing a cheap 4-cylinder hybrid engine jut to save a few bucks on gas, makes no sense....
What a HORRIBLE device!!!Stick with the orig MH bulb.The shots of the fixtures with and without the conversion was misleading-you don't get a long enough look to see what is better.Since MH lamps last longer these days due to improvements in them-will stick with the MH lamps.The LED device like most other semiconductor devices-the life IS NOT guaranteed.You may have one that last 20 yrs or another that lasts only 2 weeks.Another failure point in these besides the fan is electrolytic caps in the driver power supply.Electrolytic caps are the most failure prone electrical-electronic components.Is that F-can like driver unit sealed?-if so can't be easily repaired-replacing those bad electrolytic caps.And with the device in a somewhat enclosed fixture don't think the fan will do much good in cooling the LED arrayThe heat from the LED array and the F-can driver will be radiated into the fixture.Atleast with the MH bulb and ballast-the ballast is OUTSIDE the optical..And if it needs a fan to cool it---not so efficient is it??Another "MisLED" thing like on the thread of "misLED" people and devices.Think LED technology needs more improvement!!And do these LED lights give that sickly blue color that makes people look like zombies?At least the MH bulbs gave better color reproduction-and you could choose the color you need thru phospors and MH salts in the arc tubes.
nicksfans
I know that sickly blue color you're talking about. Reminds me of this installation. It's still one of my least favorite lighting installations that I've seen in person.
My idiot moron city replaced some lights at an intersection with LEDs. They are too small and look disproportionate with the pole. They don't put hardly any light out on the ground and are glare bombs.
randacnam7321
B-b-b-b-but EFFICIENCY!!!11 Would have a couple of 1kW incandescent high bay lights if I had a warehouse like this out of pure spite. At least the original guts of the fixture are intact so as to ease reversion to a proper lamp. Any takers for exoplanet colonization?
Old school FTW!
Saggy flourescent LED tube replacement-how SICK looking-sagging bulbs just looks too stupid.Go back to the orig flourescent bulbs-PLEASE!!At the place where I work the LED flourscent conversion bulbs work-will see for just how long-some of the orig flourescent bulbs had been back there for YEARS!!!And vintage early 60's fixtures!Sadly in some of the orig fixtures that are still orig bulbs-they are replacing the old ballasts with new SS ones.
nicksfans
Are you going to try to save the old lamps and gear?
randacnam7321
And the idiot who installed this bloody thing did not take kindly to my constructive criticism on the original video. Yay professionalism.
Old school FTW!
At my workplace unlike the outdoor mercury lights-the old bulbs and ballasts are gone.Went to the recyclers.The ballasts removed were replacements in the old fixtures anyway.Don't know how many of the orig ballasts survive.I am more into HID lights than flourescent.-but like flourescent better than incandescent and LED.The conversions have stopped for now.Think they are going to see how the LED bulbs work out.
randacnam7321
The guy in the video sounds like one of those fools that thinks that he knows everything just because he has been doing this for some integer n years and that any critics are incompetents who can be scared off with some badmouthing. And because he is a profeshunull with various meaningless certifications. Never mind that I have seen many and heard of many more quite scary examples of hackmongery done by such profeshunullz.
Old school FTW!
I've noticed that retrofitting discharge lamp fixture (Fluorescent, HID), with LED, often causes an irreparable damage to the fixture, and often result in its distruction.
