Author Topic: 400 watt metal halide uplight  (Read 10504 times)
Re: 400 watt metal halide uplight « Reply #30 on: June 03, 2015, 06:03:49 PM » Author: Solanaceae
Well some brands have diff manufacturing techniques than others so it may be why sol asked about a specific type.
Re: 400 watt metal halide uplight « Reply #31 on: June 03, 2015, 06:04:53 PM » Author: Solanaceae
Would a standard M59 universal position lamp be fine or should I find a specific type ?
are the lamps in the fixture vertical or horizontally mounted?
Re: 400 watt metal halide uplight « Reply #32 on: June 03, 2015, 07:57:45 PM » Author: sol
Sorry for the confusion : I wasn't clear with my question. What I meant is would a standard open-rated M59 universal burn lamp be fine in a base-down configuration in a fitting that is not completely enclosed. There is a gap between the reflector and the ballast housing. The original mounting position was base up, but seeing that I intend to use these upside down, then it would have a base down configuration so an open rated lamp might be the only safe solution. I hope to use standard lamps due to cost, but things are what they are and if I need open rated lamps, then I will have to find some.
Re: 400 watt metal halide uplight « Reply #33 on: June 03, 2015, 08:33:08 PM » Author: Solanaceae
I agree on using the open air rated lamps.
Re: 400 watt metal halide uplight « Reply #34 on: June 04, 2015, 01:29:17 AM » Author: Medved
The "Open fixture rating" is usually restricted for just certain operation positions only (usually the lamps are universal burn, but the open rating is just for vertical), so make sure the bulb is open rated for the base down as well.
Re: 400 watt metal halide uplight « Reply #35 on: June 04, 2015, 05:24:04 AM » Author: sol
Medved : That's what I thought ; I wanted to be sure about it. Thanks.
Re: 400 watt metal halide uplight « Reply #36 on: June 04, 2015, 11:02:47 AM » Author: Solanaceae
I agree with Medved. I Know more about merc vapor or fluorescent though.
