Author Topic: 400 watt metal halide uplight  (Read 10481 times)
400 watt metal halide uplight « on: May 31, 2015, 02:46:52 PM » Author: sol
I am considering building 400 watt metal halide up lighters for church. I can get some 400 watt MH high bays with flat glass prismatic diffusers. I would be hesitant to use them up side down for fear of overheating the glass. I am open to any suggestions you may have, however I would prefer a base-down lamp and maybe a remote ballast. This would be used indoors. Thanks.
Re: 400 watt metal halide uplight « Reply #1 on: May 31, 2015, 03:31:03 PM » Author: Solanaceae
Do you have a pic of the area you're lighting?
Re: 400 watt metal halide uplight « Reply #2 on: May 31, 2015, 03:45:27 PM » Author: sol
No, but it is a part of a church that has a 70 feet ceiling.
Re: 400 watt metal halide uplight « Reply #3 on: May 31, 2015, 04:46:25 PM » Author: Solanaceae
I think that the MH would be fine, just make sure that the glass cover will resist lamp explosions even though it is rare. Also you could use lamps that are rated for open air, normally labeled /O, for added protection versus using the /E lamps. The /O lamps have a special protective coat so that it blocks the flying glass shards from the explosions.
Re: 400 watt metal halide uplight « Reply #4 on: May 31, 2015, 08:53:20 PM » Author: sol
The glass cover is original to the fixture. What I am worried about is the fact that it is not designed to be operated in an up side down configuration.
Re: 400 watt metal halide uplight « Reply #5 on: May 31, 2015, 09:29:42 PM » Author: Solanaceae
I'd run the fixture reguular and then upside down for an hour or so. Measure the temperatures after each run, making sure to let it cool down completely. How old are the fixtures?
Re: 400 watt metal halide uplight « Reply #6 on: June 01, 2015, 05:28:28 AM » Author: sol
The fixtures were originally installed in my university's gymnasium between 1995 and 1998. They are now for sale at a local salvage yard for 30 dollars each. As far as I know, they were all working when they were taken down. The temperature differences is a good way to measure them, I might try that.
Re: 400 watt metal halide uplight « Reply #7 on: June 01, 2015, 02:36:36 PM » Author: Solanaceae
Either way, it may not hurt to add varnish. Just warn the ballast up and spray so then the varnish will get into the nooks and crannies between coils.
Re: 400 watt metal halide uplight « Reply #8 on: June 01, 2015, 07:59:23 PM » Author: Ash
Are they going to be outdoors ? If so, rain falling on the glass may well shatter it
Anyway, you can install them "normal" and do the rest of the work with mirrors
Re: 400 watt metal halide uplight « Reply #9 on: June 01, 2015, 08:39:50 PM » Author: sol
They are to be installed indoors, so the rain issue is insignificant. I thought about mirrors, but I will have to experiment with that...
Re: 400 watt metal halide uplight « Reply #10 on: June 01, 2015, 09:44:02 PM » Author: Solanaceae
I think it's a good idea with the mirrors. If you still want to mount them upside down just do the temperature measurements. If you need to you could just neatly drill vent holes or cut slots out at the top of the fixture.
Re: 400 watt metal halide uplight « Reply #11 on: June 01, 2015, 10:10:23 PM » Author: Ash
But then it will fill up with cooked insects....
Re: 400 watt metal halide uplight « Reply #12 on: June 01, 2015, 10:46:12 PM » Author: Solanaceae
You could put a metal screen like that used with windows.
Re: 400 watt metal halide uplight « Reply #13 on: June 02, 2015, 01:51:48 AM » Author: tolivac
Are these lamps High bay ones meant for ceiling mount? I have many lights like that and run them with the ballast on the floor with no problems.400W MH and HPS(use the Philips Master color bulbs in them)and a 450W Pulse start MH Widelight from the old Michlen tire factory.The lights work just fine--with the optical above the ballast--as "upside down" the ballast runs cool.The lights I have came from contractors replacing the older lights with flourescent ,LED,or pulse start MH.
Re: 400 watt metal halide uplight « Reply #14 on: June 02, 2015, 05:31:10 AM » Author: sol
They are in fact highbays meant to be suspended from the ceiling. They have a prismatic flat glass factory installed on the reflector. There is a gap between the top of the reflector and the ballast housing, though. Upside down would be the best way to use them as up lighters, though. They have been used for years with standard M59 lamps (not open rated). I don't have pictures of them and I can't get them until the weekend as the salvage yard is only open on Saturday and on Sunday.
