Author Topic: Vintage lamps (tubes bulbs) I am currently using  (Read 4089 times)
dspiffy
Vintage lamps (tubes bulbs) I am currently using « on: March 03, 2015, 04:38:33 AM » Author: dspiffy
I noticed that several of the bulbs in my shop fixtures were very dirty, so I removed them to clean them, and took pictures while I was at it.
randacnam7321
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #1 on: April 11, 2015, 11:56:04 PM » Author: randacnam7321
I usually pull any oddball/rare lamps from service to save them as specimens.  The only exception to this is a Westinghouse 155V 6S6 lamp that I have in a night light.  I only use it because I have a bag of them.  Little feller has lasted well over a year so far.  Still running as I write this.
Old school FTW!
hannahs lights
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #2 on: April 16, 2015, 04:44:47 AM » Author: hannahs lights
The nitelite you mention is it 155 volt rated or does the 155v mean something else? I ask because as far as I know 150 volt mains was last seen in Europe back in the 1960s so that would make it a really old lamp at least 50 years!
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #3 on: April 16, 2015, 09:11:29 PM » Author: sol
155V incandescent low wattage indicator lamps are sometimes used on 120V mains to increase lifetime. They were, I believe, used in some types of trains that ran on 145 volts, but I am not sure. Some are still available today and are sometimes marked as extra long life.
I had a 120V 6S6 lamp with a deformed base and it would not fit in any of my indicator switches but fit nicely in a night light. It lasted about 14 months and the filament broke (it was a PC night light). I shook the bulb slightly and the break reconnected. It lasted about another 14 months before breaking in several places. Now I use a standard 4w C7 and the light no longer reacts to itself (reflection from the soap bottles by the sink).
nicksfans
Down with lamp bans!
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #4 on: April 17, 2015, 09:07:18 PM » Author: nicksfans
Some exit signs use 145V T6 incandescents at 120V.
My Gallery
Instagram
YouTube
jrmcferren
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #5 on: April 18, 2015, 05:42:14 PM » Author: jrmcferren
A 155 volt indicator lamp would be the proper type to use in some utility switchgear. The bus is 130 vols DC nominal, but as the battery is being re-charged it would reach nearly 155 volts prior to being dropped to floating voltage to float the bank between cycles), plus on 120 volt circuits it would last longer.
Re: Vintage lamps (tubes bulbs) I am currently using « Reply #6 on: May 19, 2015, 10:20:35 PM » Author: Solanaceae
Save those lamps, those look pretty old and will be rare soon. I was lucky enough to snag rare NOS ITT and Ken Rad mercs from being put into servect
