Author Topic: Want some opinions regarding lamp current  (Read 2536 times)
themaritimegirl
Florence
themaritimegirl
Want some opinions regarding lamp current « on: May 21, 2014, 08:41:45 PM » Author: themaritimegirl
Hi all,
I'm planning on building an incandescent-ballasted F14T12 fixture. According to the Advance fluorescent lamp troubleshooting guide, the F14T12 is rated for 0.38A of current. I've gone through all my incandescent light bulbs, and I've narrowed it down to two bulbs; a 40 watt unit which feeds the lamp with 0.27A, and a 60 watt unit which feeds the bulb with 0.39A.
My question is, which do you guys think would be better for the bulb, a 25% underdrive or a 3% overdrive? Normally I would accept a slight underdrive over a slight overdrive, but given how little the overdrive is, I'm willing to consider both. I'm also considering the 60 watt bulb because the higher current lets the bulb start easier, which is a challenge on an incandescent ballast. However, a vintage lamp which I just acquired will be used for this fixture, so preserving lamp life is my top priority in choosing which incandescent bulb to use.
Thanks for any imput.
« Last Edit: May 21, 2014, 08:44:36 PM by TheMaritimeMan » Logged
BscEE and Television Producer
YouTube | Mastodon
Re: Want some opinions regarding lamp current « Reply #1 on: May 22, 2014, 12:34:15 AM » Author: Medved
The 3% overdrive won't be of any problem at all.
I assume the currents are the measured ones, which type of meter have you used for that?
themaritimegirl
Florence
themaritimegirl
Re: Want some opinions regarding lamp current « Reply #2 on: May 22, 2014, 12:36:26 AM » Author: themaritimegirl
Thanks for the input. I'll probably use the 60 watt then since it will make starting a lot more reliable. Current was measured using my Kill-A-Watt meter.
YouTube | Mastodon
Re: Want some opinions regarding lamp current « Reply #3 on: May 22, 2014, 12:41:31 AM » Author: Medved
But there will be quite severe losses, the whole assembly will emit less light than a 50W incandescent...
I would rather use two lamps in series, the ballast would be most likely a 100W or 75W incandescent (you will have to try, which gives the closest current value)
themaritimegirl
Florence
themaritimegirl
Re: Want some opinions regarding lamp current « Reply #4 on: May 22, 2014, 12:43:30 AM » Author: themaritimegirl
As always with my experiments, efficiency is the least of my concerns.  :D
YouTube | Mastodon
