Author Topic: Megaman vid  (Read 5469 times)
imj
Megaman vid « on: July 30, 2007, 06:47:11 AM » Author: imj
http://www.youtube.com/watch?v=tf-LOmMZoIw
J-Frog
Re: Megaman vid « Reply #1 on: September 13, 2007, 09:33:37 AM » Author: J-Frog
I believe Megaman is the company that made the Ikea CFLs, and I did see some apparent Ikea CFL lookalikes in that cool video!
Jeremiah The Bullfrog
prawnman88
Re: Megaman vid « Reply #2 on: September 15, 2007, 11:32:54 AM » Author: prawnman88
i agree also i have some ikea lamps and there still going strong and there 3 years old and just regular use but.  i have to say i like them alot says alot for china junk but hey maybe there making them better now at least megaman is
lightman64
Re: Megaman vid « Reply #3 on: January 24, 2009, 08:00:45 PM » Author: lightman64
so thats what it looks like when they make china junk!
TudorWhiz
Re: Megaman vid « Reply #4 on: January 25, 2009, 12:28:45 AM » Author: TudorWhiz
The Megaman you saw on the video is actually the better China stuff....not the badly made ones....
lightman64
Re: Megaman vid « Reply #5 on: July 25, 2009, 11:20:37 AM » Author: lightman64
Megaman is actually a good brand. I have some IKEA lamps and they all are still going strong. Megaman doesn't use Instant-start ballasts either, usually programmed start.
Re: Megaman vid « Reply #6 on: July 29, 2009, 04:30:54 PM » Author: Medved
Recently i made bad experience with Megaman: I bought their "DorS" dimmable globe for about $35 (when i recalculate it by the rate i remember; it was CZK~560).
It is 4 wide-bent parallel T3 U-tube configuration with the outer glued by the silicone glue to the socket plastic.
First they by far do not meet the declared 5% minimum dimming level (the reason i bought it instead of my preferred OSRAM), it is 15% in reality (and as i checked it later, this value is not caused by driver's tolerance, but value programmed in the embedded microcontroller, so they know they do not meet this; with some mods i was able to lower it down to ~4%)
Second the globe outer was quite loose, what trigger me to look inside, it get's very easilly off, the glue touches both surfaces only on ~1/4 of perimeter (for sure it was intended to hold it around whole perimeter)
After removing the outer, i saw something i'm not used to see even on very cheap china junk: Visibly uneven phosphor deposition and this on STRIGHT tube sections! I guess the lamp could have easilly at least 30% higher efficacy, only by better manufacturing quality control.
I was really not ready to see so many quality problems on one, single, so expensive lamp.
I got strong impression, Megaman (or better say their production labor) does decently only stuff, that is visible, the rest is crappy, totally ruining the otherwise good design.
