Author Topic: western electric sunbeam Mazda  (Read 3364 times)
blueline
western electric sunbeam Mazda « on: January 05, 2014, 10:17:53 AM » Author: blueline
I found this cool bulb in a dresser I bought at a thrift store. It appears the filament is continuous.  From what I could find, it was made between 1915 - 1920?  Are these rare? Can I screw it into a lamp to see if it works or would that break it? I was thinking I could put it on a dimmer with dimmer dialed down to not break the filament? Thanks!
DetroitTwoStroke
Luke
Re: western electric sunbeam Mazda « Reply #1 on: January 09, 2014, 04:03:30 PM » Author: DetroitTwoStroke
That does look like an old one - neat find! Generally, it is a good idea to test old incandescent bulbs on a dimmer to reduce the thermal shock to the filament.
Re: western electric sunbeam Mazda « Reply #2 on: January 21, 2014, 10:47:07 PM » Author: funkybulb
I have one a bit older than this but it made before 1920s
I think. This is a good piece to hang on to for sure.
A variac is the best. But a dimmer will do but dont run a dimmer to max as these vintage lamps rated 110 volts
As our line voltage is  near 120 volts, my line voltage can reach as high as 128 volts.
nicksfans
Down with lamp bans!
Re: western electric sunbeam Mazda « Reply #3 on: February 06, 2014, 08:44:11 PM » Author: nicksfans
I have one that is very similar to this, if not the same. Mine still lights.
My Gallery
Instagram
YouTube
