Author Topic: Lighting technologies after the LED already being discussed  (Read 2496 times)
Silverliner
Rare white reflector
Lighting technologies after the LED already being discussed « on: October 05, 2013, 01:16:34 AM » Author: Silverliner
I just saw this video on youtube about some talk of a strong possibility that the already new LED lighting could be replaced by laser technology someday. I read somewhere that lasers are said to be even more efficient than LEDs and do not suffer the problem of efficacy droop as they get brighter. Less optical losses as well. What do you think guys?
http://www.youtube.com/watch?v=Xyw9eflGSZA
Member of L-G since 2005.
Electrician.
imj
Re: Lighting technologies after the LED already being discussed « Reply #1 on: October 05, 2013, 01:43:56 AM » Author: imj
Nice..:).
« Last Edit: October 05, 2013, 01:48:11 AM by imj » Logged
Re: Lighting technologies after the LED already being discussed « Reply #2 on: October 05, 2013, 02:52:58 AM » Author: dor123
Laser produces a very concentrated light with monochromatic wavelengths and with beams of less than 1 degree. So how they can be used to light a room beside pointing a 1W green laser to a ceiling, then its beam reflected light will illuminate the room?
The lightsource should be diffused from the begining to be usefull for lighting.
Re: Lighting technologies after the LED already being discussed « Reply #3 on: October 05, 2013, 05:16:09 AM » Author: Medved
With lasers, I don't think they will be here AFTER the LED's, but rather TOGETHER with the LED's.
Their only advantage (and at the same time a disadvantage) is, laser provide coherent rays. It come as an advantage, when you need precise beam control, as the area of the virtual source aperture is zero, so infinite brightness. So you may shape the beam whatever you like without loosing the light even with compact optics.
The disadvantage is, it bring qualitatively new effect, what could be quite disturbing: Interference artifacts.
And the fact, than most laser devices emit only one, single, wavelength, so you would need multiple of them, perfectly aligned, to produce a white beam for direct illumination for human visibility.
I know about one system using laser in car headlights: Laser illuminate the phosphor layer and the resulting white spot is then projected onto the road. The shape of the area on the phosphor layer illuminated by the laser form then the final beam shape. The main advantahe and in fact the reason for this approach was, it allow to shape the beam so, the lights on "high" have a dark "hole" in the beam just in the direction of an approaching car, so they could remain at "high beam" all the time without causing glare.
There are other methods for the same task (shields, LED "PixelLight" ,...), the laser system allowed to use only simple miniature scan (simple piezo or electromagnetic actuators) so do all the movements.
