Author Topic: Philips "Natural Light" tubes: same specs, different tints  (Read 7469 times)
jrmcferren
Re: Philips "Natural Light" tubes: same specs, different tints « Reply #15 on: August 01, 2013, 08:13:21 AM » Author: jrmcferren
I see the 4000K halophosphors, as brownish white, in a 6500K halophosphors atmosphere. If viewed alone, they looks more pinkish white.
2700K and 3000K halophosphors, looks as a very ugly warm brownish or pinkish white
3000K colour called "Soft white" in the US also for fluorescents, not only LEDs.
2700K triphosphors looks like a warm pinkish yellow white or simply a yellowish white at the home, and it is good at homes. But at supermarkets, it looks like an ugly warm brownish pinksih yellowish colour, which is why I don't prefers <3500K lights at commercial locations.
4000K triphosphors, usually looks similar in shade to a yttrium vanadate coated self ballasted mercury lamps (Such as my Philips ML 160W and Osram HWL 160W).
The typical designations on US lamps are as follows (FYI):
Fluorescent and LED Marketing:
2700K: Soft White (a real soft white would be 2850K though)
3000K: Warm White (especially halophosphor), Halogen White, and rarely soft white
3500K: White (halophosphor), Neutral White, [Original color from 1930s]
4100K/4200K: Cool White
4500K: Industrial White (Obsolete) [early attempt at Cool White]
5000K: Bright White (Generic), Chroma 50 (GE), Colortone 50 (Phillips), Design 50 (Osram Sylvania)
6500K: Daylight [Original from 1930s]
LED (Semiconductor Industry)
2700K-4000K: Warm White
4000K-7000K: Cool White
toomanybulbs
Re: Philips "Natural Light" tubes: same specs, different tints « Reply #16 on: August 01, 2013, 08:29:24 AM » Author: toomanybulbs
when i ordered luxeon rebels for a project they were 4000k and called neutral white.
they look a lot like an 840 phosphor.
and i agree with 123 that too much marketingspeak is attached to "full spectrum"
maybe call them fuller spectrum or improved spectrum.lots of hype attached to ottlite,vitalite,verilux,ect for just a generic off the shelf bulb that nearly all manufacturers make in some form.
Cavannus
Re: Philips "Natural Light" tubes: same specs, different tints « Reply #17 on: August 01, 2013, 01:11:08 PM » Author: Cavannus
I agree, and I think this is due to the higher levels of illumination in stores and supermarkets than in homes (as per the Kruithof curve).
