Author Topic: Biggest and highest wattage lamp  (Read 9406 times)
FGS
Rory Mercury!
Biggest and highest wattage lamp « on: July 06, 2007, 04:43:41 PM » Author: FGS
What is the biggest bulb in the world? What is the highest wattage ever reached by a bulb company? One is a german lamp. It is big and is 50Kw lamp. It is here: http://blog.modernmechanix.com/mags/qf/c/ScienceAndMechanics/11-1931/med_big_bulb.jpg
form109
Re: Biggest and highest wattage lamp « Reply #1 on: February 27, 2009, 09:49:10 PM » Author: form109
that is the Biggest Light bulb i've ever seen!!!!! :o :o :o :o :o
Silverliner
Rare white reflector
Re: Biggest and highest wattage lamp « Reply #2 on: February 27, 2009, 10:56:35 PM » Author: Silverliner
Westinghouse made a 75,000 watt lamp! Also, I've seen the 50,000 watt lamp made by GE in person. The filament is HUGE, the actual diameter is quarter of an inch thick!
Member of L-G since 2005.
Electrician.
Re: Biggest and highest wattage lamp « Reply #3 on: February 28, 2009, 05:17:42 AM » Author: Medved
I read somewhere about 100kW incandescent, i think it was German, but i'm not sure. It was some sort of sun-simulating lamp from before 20's.
Parrot
YouTube: Parrot175
Parrot175 parrot175
Re: Biggest and highest wattage lamp « Reply #4 on: January 12, 2010, 08:46:41 PM » Author: Parrot
That is one big bulb!!! What is it for a floodlight or a light house?
Re: Biggest and highest wattage lamp « Reply #5 on: January 13, 2010, 02:10:17 PM » Author: Medved
It was described as laboratory use sun simulator...
bluelights
Re: Biggest and highest wattage lamp « Reply #6 on: January 13, 2010, 02:37:38 PM » Author: bluelights
http://www.aaroncake.net/forum/topic.asp?TOPIC_ID=6011
Save the mercury lamp
gailgrove
MVs at Dusk
Re: Biggest and highest wattage lamp « Reply #7 on: January 13, 2010, 02:54:42 PM » Author: gailgrove
:o :o :o :o :o :o (faint)  ;D
Say no to Induction & LED, HID forever!
Re: Biggest and highest wattage lamp « Reply #8 on: January 13, 2010, 03:27:06 PM » Author: Medved
Yep, this is what i meant...
lite_lover
Darren
GoL darren.harward
Re: Biggest and highest wattage lamp « Reply #9 on: January 13, 2010, 03:53:57 PM » Author: lite_lover
WOW  :o :o :o :o That's one BIG bulb!
The brighter the better.
Re: Biggest and highest wattage lamp « Reply #10 on: January 13, 2010, 04:14:41 PM » Author: joseph_125
Whoa! :o that's a huge bulb, that thing should draw a lot of current considering it's a 115V bulb  ;D .
Re: Biggest and highest wattage lamp « Reply #11 on: January 14, 2010, 01:19:36 PM » Author: Medved
... only 870A - you need quite thick wires to drive this one!
If we exclude the multi-megawatt carbon-arc sky trackers that were made during WWII,...
Why to exclude, do you have some pictures of them? They should be interesting to know more about...
This monster is cooled with an inner water flow (yes, inside the burner) and is used for (surprisingly) solar simulation.
Here is some info about it's little brother of only 100 kW: http://www.pre.ethz.ch/facilities/vortec/
and about the 300 kW model: http://www.ornl.gov/info/ornlreview/v35_3_02/lamp.shtml
I think the second is not used for solar simulation, but material processing...
kai
Re: Biggest and highest wattage lamp « Reply #12 on: April 04, 2010, 11:05:28 PM » Author: kai
What were in detail the most powerful searchlights?
Various websites suggest than common models run at 110 V / 200 A, thus 22 kW. Wikipedia vaguely mentions bigger searchlights with 200 cm diameter, powered by a 120 kW generator, which suggests a power consumption of the arc somewhere between 50 and 100 kW. Such figures have also been mentioned in a book from the fifties for fixtures in large movie studios. Such beasts were necessary for the first colour film stocks with a sensitivity of a mere ISO 16/13°.
