Author Topic: Thread in other forum about Russian and Soviet lamps  (Read 3153 times)
Thread in other forum about Russian and Soviet lamps « on: May 28, 2013, 12:44:28 PM » Author: Ash
I spotted some Osram st111 BASIC starters in a shop here. Usually the Basics are from China and use IU glowbottle, but this time..... They have some "other world" look to them right away, and i took one and looked at it closer - Made in Russia - did not see them before..
They are exactly like this : http://portuguese.alibaba.com/product-gs/osram-starter-st111-cheap-starter-green-starter-flourescent-starter-699757295.html
Becoming interested, i googled a bit. They are made in Smolensk lamp factory (est 1963, existed under its original name at least up to 1988). currently owned by Osram
Last photo : http://www.rabochy-put.ru/topnews/17143-vtoroe-rozhdenie-smolenska.html
Then i googled about the factory under its original name Смоленский электроламповый завод and found this thread. They discuss the etches of various Soviet tubes,, where they were made etc. Generally appear like intersted in lighting - i actually checked if the site is sorta "Russian Lighting Gallery" but no, its a general "vintage electronics" forum, in a more general site, with a thread about vacuum valves that gone a bit on lamps for a few posts
So here it is : http://offtop.ru/dustyattic/v1_624303_14_.php
Made for some interesting browsing
« Last Edit: May 28, 2013, 12:50:27 PM by Ash » Logged
migette1
Peter
migette1
Re: Thread in other forum about Russian and Soviet lamps « Reply #1 on: July 02, 2013, 04:26:18 AM » Author: migette1
Hi Ash
Must have a look at that Russian site as Russian lamps have been appearing on eBay including funnel shaped filaments which I have put up somewhere here or ATL or GoL. I must put up a flicker neon from USSR also. Thanks for the info Ash.
Interested in the history of electric lighting and incandescent in particular and neon glow lamps.
