Author Topic: Deleted  (Read 2613 times)
imj
Deleted « on: April 21, 2013, 02:01:52 PM » Author: imj
Deleted
« Last Edit: June 23, 2013, 12:50:55 PM by imj » Logged
Re: 2x58w T8s preheating circuit not successfull..:( « Reply #1 on: April 21, 2013, 02:17:12 PM » Author: Ash
Are the lamps in parallel ?
Re: 2x58w T8s preheating circuit not successfull..:( « Reply #2 on: April 22, 2013, 02:00:02 AM » Author: Medved
May you draw the exact schematic? (or repost a link, if you have already published it)...
Re: 2x58w T8s preheating circuit not successfull..:( « Reply #3 on: April 22, 2013, 02:47:09 PM » Author: Ash
All i can see here is minor dependance between the lamps by sharing the preheat current on their neutral-side electrodes. But i seen somewhat similar situations in miswired ordiunary 2x36w fixtures (both lamps with neutral on the same side, and starter wires crossed between tem) and as long as both lamps are intact those fixtures dont have a problem to strike both lamps
Re: 2x58w T8s preheating circuit not successfull..:( « Reply #4 on: April 22, 2013, 04:13:55 PM » Author: Medved
I was thinking that too since a simple preheat circuit has been complexified many times...LOL.
Just to have a clue, what did you do there - as you said, there are endless possibilities...
