Author Topic: Why the broken MV lamp inside the Gaash Hila lantern, have brightness variations  (Read 2428 times)
Why the broken MV lamp inside the Gaash Hila lantern, have brightness variations « on: November 27, 2012, 02:36:37 PM » Author: dor123
Today, at mid-night, the right of the three Gaash Hila lantern, that have a broken MV lamp, came back to life, and the lamp lit after a week or so that it wasn't operated.
One thing that I noted, is that the broken MV lamp in the lantern, varies in brightness , which its brightness and light intensity rises and falls randomally.
Sometimes the lamp is so dim that it is almost don't light the area, and sometimes it lights very strongly like an intact yttrium vanadate coated 125W MV lamp (But with a greenish white color).
What can cause this?
mrboojay
I love bulbs of all types.
mrboojay UC2tpasJaLc8IhVdjcDkI_3A mrboojay mrboojays_pics
Re: Why the broken MV lamp inside the Gaash Hila lantern, have brightness variations « Reply #1 on: November 29, 2012, 12:18:35 AM » Author: mrboojay
It could be that the temperature of the arc tube keeps changing so the light is varied.  It could also be that maybe it is just old and has a lot of hours on it so it has trouble keeping a stable arc.  It could also be a combination of both.  Hope this helps.
-mrboojay
My lighting-gallery.net Gallery
My YouTube Channel
Re: Why the broken MV lamp inside the Gaash Hila lantern, have brightness variations « Reply #2 on: November 29, 2012, 11:34:58 AM » Author: Ash
If this is erlated to atmospheric teperature (rain --> dim) then it may be arc tube temperature
Anoher option is bad connection, esp if corrosion is present. Since there are no moving parts, the connection may actually be quite stable, just with varying resistance (hot spot --> corrosion --> bad contac --> arcing --> welding itself a bit better --> heating less but new metal exposed and at high temp --> and so on)
