Author Topic: My Osram HWL 160W, often wildly flickering  (Read 2671 times)
My Osram HWL 160W, often wildly flickering « on: November 24, 2012, 12:07:35 PM » Author: dor123
My Osram HWL 160W SBMV lamp in my room in my father home, often wildly flickering. Sometimes it have a very noticeable visible flickering, sometimes the flickering stop and become invisible.
Why this is happening?
Re: My Osram HWL 160W, often wildly flickering « Reply #1 on: November 24, 2012, 12:35:45 PM » Author: Ash
i seen this a lot in reflector mercury lamps in Osram Floraset fixtures. Te oes that flicker are dimmer than the others and greened out
So maybe lamp aging
also try to take the lamp out of the socket, flip it a few times (dont really shake it to not break the filament) and put it back, see if it helps
Rich, Coaster junkie!
Re: My Osram HWL 160W, often wildly flickering « Reply #2 on: November 24, 2012, 04:06:24 PM » Author: AngryHorse
You will get a flickering from the discharge tube, as the arc wanders around the overwinds of the electrodes too.
Could also be voltage fluctuations?
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
Re: My Osram HWL 160W, often wildly flickering « Reply #3 on: November 25, 2012, 04:22:55 AM » Author: dor123
The arctube stay in the same position, when the lamp flickers.
Seems to be indeed more of voltage fluctuations.
Re: My Osram HWL 160W, often wildly flickering « Reply #4 on: November 25, 2012, 10:57:41 AM » Author: Ash
Nope it is lamp. i have a Philips HPL-N 125w from 1989 that is doing the same
