Author Topic: A phenomenon that i have seen in new HPS retrofit for MV ballasts in videos  (Read 2308 times)
A phenomenon that i have seen in new HPS retrofit for MV ballasts in videos « on: April 10, 2012, 07:05:04 AM » Author: dor123
While there are some HPS retrofits for MV ballasts that turns from red neon to bluish mercury and then to orange sodium, i have seen in many videos of some members here, that new HPS retrofits lamps that turns from red neon to orange sodium without the bluish mercury color in between, tends to turn for a second to a xenon like white color between the red neon to the orange sodium color.
Why this is happening? Is this also related to the mercury in the lamps?
Re: A phenomenon that i have seen in new HPS retrofit for MV ballasts in videos « Reply #1 on: April 10, 2012, 10:46:30 AM » Author: Ash
IDK but i see it with our "normal" HPS too
I have GE Lucalox SON-E 150W that does not go through mercury color, and few other 150W HPS's that do go through mercury color
It is also related to lamp age - older lamp tends to light more in mercury color
Re: A phenomenon that i have seen in new HPS retrofit for MV ballasts in videos « Reply #2 on: April 10, 2012, 11:53:18 AM » Author: dor123
Ash: I don't means why several HPS have mercury color after starting.
I means why neon based HPS retrofits for MV ballasts that don't shows the mercury color during the move from the red neon color to the orange sodium color, exhibits a xenon like white color for a sec between the red and the orange color, as i saw in videos?
This question may only be answered by other members, as we haven't these lamps in Israel.
Probably this is a camera AWB that causes this color, and in reality this is a colors mixture of the merucry+sodium colors?
lantern_vision can answer this, as he have numerous neon based HPS retrofit for MV ballasts.
BG101
EYE H80 Mercury Vapour
Brian TheTellyman
Re: A phenomenon that i have seen in new HPS retrofit for MV ballasts in videos « Reply #3 on: April 10, 2012, 01:43:08 PM » Author: BG101
If you've only actually seen this on videos then there is no way to judge it because as you say, white balance will probably come into play and cameras (also monitors to some degree) tend not to be very colour-accurate with high intensity light sources. Even decent cameras struggle with colour purity on things like neon signs.
BG
