Author Topic: unusual switch start ballast finds  (Read 2795 times)
unusual switch start ballast finds « on: April 05, 2012, 12:19:58 AM » Author: funkybulb
here is the unusual switch start ballast find it surpise me i found and bought this on USA ebay
this is 120 volts 60Hz compare to the 240 volts 50 hz ballast
this can do 1 30 watt T12 or series 15 watt T12 on switch start ballast
these tube will still be around ;D
http://www.ebay.com/itm/190650710352?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Last Edit: April 05, 2012, 12:22:25 AM by funkybulb » Logged
Re: unusual switch start ballast finds « Reply #1 on: April 05, 2012, 02:57:12 AM » Author: Ash
It is (auto?)transformer ballast - like HX
You can tell by that the line current is higher than lamp current which means that it is a step up transformer. The 4 connections are a hint too though there are ballasts that connect to the N too and are not transformers
Re: unusual switch start ballast finds « Reply #2 on: April 05, 2012, 05:28:24 AM » Author: dor123
I don't see any picture at all in the link.
Re: unusual switch start ballast finds « Reply #3 on: April 05, 2012, 09:13:45 AM » Author: funkybulb
it look like an auto transfomer. not only that it also look like it was intended to sold on american market
becase it UL approve ballast. does any one know how old that ballast is?
well this is going in my american fluorescent F30 fixture that i found badly rusted. going to sand it down and repaint it.
Re: unusual switch start ballast finds « Reply #4 on: April 05, 2012, 10:33:18 AM » Author: dor123
I found how to view the picture.
The ballast have an european style, and is probably an export ballast to the US.
I compared it to an Eltam magnetic choke ballast for 36W T8, and as this ballast have four wires instead of two, i think that this is truly an autotransformer ballast and not a choke ballast.
