Author Topic: led lamp review  (Read 26463 times)
marcopete87
Re: led lamp review « Reply #45 on: December 26, 2013, 04:11:07 PM » Author: marcopete87
i have 12.5W remote posphor, this: http://www.lamptech.co.uk/Spec%20Sheets/LEDi%20230-12K58RP830-B22d%20Philips.htm
i hope in an replacement, because an 40€ lamp can't simply fail after 3000h of usage in open luminaire  :-\
Re: led lamp review « Reply #46 on: December 26, 2013, 04:15:14 PM » Author: Medved
... because an 40€ lamp can't simply fail after 3000h of usage in open luminaire  :-\
Well, apparently can...
marcopete87
Re: led lamp review « Reply #47 on: December 26, 2013, 04:24:57 PM » Author: marcopete87
troll lamp?   ;)
Rich, Coaster junkie!
Re: led lamp review « Reply #48 on: December 26, 2013, 06:01:46 PM » Author: AngryHorse
I was so tempted to use these, but went with the Megaman lamps instead, Megaman put a more realistic 15,000 hours life on theirs. ;)
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
marcopete87
Re: led lamp review « Reply #49 on: December 27, 2013, 07:15:03 AM » Author: marcopete87
they are sending me an replacement lamp  ;D
i hope i can keep the broken one
Re: led lamp review « Reply #50 on: December 27, 2013, 09:25:10 AM » Author: Medved
When that was an isolated incident, I would expect they will ask it back - to study, what went wrong.
Well, maybe too naive, I'm used to such approach in the automotive industry...
marcopete87
Re: led lamp review « Reply #51 on: December 27, 2013, 10:50:49 AM » Author: marcopete87
this will be interesting to know what caused this failure.
Re: led lamp review « Reply #52 on: December 28, 2013, 09:43:10 PM » Author: RyanF40T12
It's a Philips, there's your answer right there :)
toomanybulbs
Re: led lamp review « Reply #53 on: December 29, 2013, 11:32:28 AM » Author: toomanybulbs
if so we expect an autopsy.
remember that no matter who makes a device there will be some duds.
the higher the parts count the more chances of having a failure.
Re: led lamp review « Reply #54 on: December 29, 2013, 07:09:40 PM » Author: RyanF40T12
no doubt.  Just messing with ya.  I respect some of the Philips products, i just tend to favor the old powerhouses like Sylvania and GE is all.  Philips use to make some of the best fluorescents and incandescents years ago and their first gen of T8 ALTO F32T8s 70 series easily outlasted anything put out by Osram/Sylvania and GE.  Sadly their second generation of ALTOs just flat out suck with very very weak filaments and horrible lamp life.
marcopete87
Re: led lamp review « Reply #55 on: December 30, 2013, 01:51:58 PM » Author: marcopete87
i hope to receive it before the next year  ;D
however, if i can keep this broken lamp, i'll try to reveive it, replacing what failed.
Re: led lamp review « Reply #56 on: December 30, 2013, 03:37:40 PM » Author: Medved
Did they asked you to send the faulty lamp back?
marcopete87
Re: led lamp review « Reply #57 on: January 01, 2014, 05:48:46 PM » Author: marcopete87
actually no, they asked me to keep the fault one with original check and box (i kept all); if they ask, i'll send the lamp.
Yesterday i noted some bad smell near the ballast housing.
marcopete87
Re: led lamp review « Reply #58 on: January 14, 2014, 02:48:20 AM » Author: marcopete87
update: philips customer service don't respond me, i asked about replacement, but they seems to ignore my request.  >:(
update 2: today i received the replacement; it isn't the same lamp, but works well, thank you philips!  :D
« Last Edit: January 17, 2014, 08:36:38 AM by marcopete87 » Logged
marcopete87
Re: led lamp review « Reply #59 on: January 17, 2014, 11:56:37 AM » Author: marcopete87
update 3: i managed to revive the lamp, during autopsy, i noted some bad soldering on the wire that connect one led module.
now it works!  :)
