Author Topic: mobilite 140 desk lamp 2x8w t5.overdriving lamps?  (Read 2382 times)
toomanybulbs
mobilite 140 desk lamp 2x8w t5.overdriving lamps? « on: March 10, 2012, 08:46:16 AM » Author: toomanybulbs
found this on the curb recently.
has 2 8w t5 in series with a push and hold to start button.
one of the tubes had an open heater when i first tried it.
put in some known good ones and it works but you can see the heaters glow bright orange while it is running.its also brighter than 2 8w t5 should be.killawatt shows .26a while warmed up.
ballast does not get too hot.
was this thing designed to drive the tubes this hard?
« Last Edit: March 10, 2012, 08:55:20 AM by toomanybulbs » Logged
Re: mobilite 140 desk lamp 2x8w t5.overdriving lamps? « Reply #1 on: March 10, 2012, 11:50:29 AM » Author: Medved
The 0.26A is mains or lamp current?
The f8t5 is supposed to be driven at 0.17A.
Was the ballast really original?
I have an impression like someone thought: "2x8W = 16W, so lets use the 15..20W ballast"...
toomanybulbs
Re: mobilite 140 desk lamp 2x8w t5.overdriving lamps? « Reply #2 on: March 11, 2012, 09:35:38 PM » Author: toomanybulbs
its even higher when cold.
going to open it up and see whats in the base.
