Author Topic: CFL's in series  (Read 4692 times)
lightboy90
CFL's in series « on: April 09, 2007, 03:35:48 PM » Author: lightboy90
I've a  question: When two CFL's are switched in series, does the twice lamp work when one lamp is defect? Normally not, or?
TudorWhiz
Re: CFL's in series « Reply #1 on: April 10, 2007, 03:30:05 PM » Author: TudorWhiz
i have seen PL CFL in fixtures strobing like a defect preheat fixture......they were wired like this.....digram I drew..... so what happens if one PL is defect is one would flash faster than the other....i ma not sure which flashes faster........but you get it........
SeanB~1
Re: CFL's in series « Reply #2 on: April 12, 2007, 04:13:13 PM » Author: SeanB~1
If electronic ballasted then both will blow when 1 fails. The 2 in series with magnetic ballast both will flicker, change as a pair always. They can be hard to atart on low mains or when cold. For separate starters you have to use Osram ST151 as opposed to ST111 for 220V use.
