Author Topic: Can a 100W MV bulb be operated on a 175W H39 ballast.  (Read 2890 times)
Lightguy
Can a 100W MV bulb be operated on a 175W H39 ballast. « on: February 09, 2012, 07:38:42 PM » Author: Lightguy
Im just wondering because I have a nema with a 175 watt ballast.I have also a 100W bulb that I never fired up.I was thinking about changing the mogul socket with a medium socket,and rewire it that way.Just let me know.I really want to operate that 100w bulb.
N.A. ;)
LowPressureSodiumSOX
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #1 on: February 09, 2012, 07:59:28 PM » Author: LowPressureSodiumSOX
I wouldn't recommend doing so, as there is a (rather high) chance of a arc tube explosion, as the vapor gets overheated. It should start, though. The lamp, however, should start fine, and may even run up fine, though the certainty of a reduced life.
Lightguy
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #2 on: February 09, 2012, 08:10:56 PM » Author: Lightguy
How about leaving the bulb on for one minute?
N.A. ;)
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #3 on: February 09, 2012, 08:18:53 PM » Author: LowPressureSodiumSOX
Probably could,(I still wouldn't recommend it), but probably should cover it up to prevent the chance of an explosion of the arc tube.
slipperypete
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #4 on: February 09, 2012, 08:36:46 PM » Author: slipperypete
I was talking with MEDVED and ASH on a similar subject and they both said the same thing that lowpressuresodiumsox said.  You might be able to get some time out of it,  but no guarantee.
Bulb bans = Fascism
slipperypete
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #5 on: February 09, 2012, 08:38:47 PM » Author: slipperypete
If power consumption is a concern you could try using a LOA 65 Watt buster bulb.
Bulb bans = Fascism
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #6 on: February 10, 2012, 07:09:58 AM » Author: Medved
Or as I already wrote on other places, the 100W MVis compatible with 70W pulse start MH ballast (I forgot it's ANSI code), you only have to deactivate the ignitor.
Lightguy
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #7 on: February 10, 2012, 12:53:20 PM » Author: Lightguy
Im just going to put a post for a 100W MV Ballast on LG on the wanted page.
N.A. ;)
slipperypete
Re: Can a 100W MV bulb be operated on a 175W H39 ballast. « Reply #8 on: February 10, 2012, 01:02:21 PM » Author: slipperypete
Ask icefoglights.  I think he might have a stash.
Bulb bans = Fascism
