Author Topic: What is a Auto Regulator Ballast?  (Read 3598 times)
Parrot
YouTube: Parrot175
Parrot175 parrot175
What is a Auto Regulator Ballast? « on: February 07, 2012, 05:56:46 PM » Author: Parrot
This might be a simple question for some of you but I don’t know what a "auto regulator" ballast does. I was on graybar looking at some GE street lights and noticed that some have this auto regulator ballast and some have a NPF ballast. What is the difference between a NPF ballast and a auto regulator ballast? Also what one is better? Thank You for helping!  :)
Re: What is a Auto Regulator Ballast? « Reply #1 on: February 07, 2012, 09:19:43 PM » Author: sol
My guess would be an autotransformer (probably CWA) ballast, as is quite common in North America. Just a thought...
Re: What is a Auto Regulator Ballast? « Reply #2 on: February 08, 2012, 01:01:03 AM » Author: Ash
CWA Indeed. It controls the output power (rather than output current which is what other ballasts tend to do) so has better stability with line voltage fluctations
Re: What is a Auto Regulator Ballast? « Reply #3 on: February 08, 2012, 02:50:34 AM » Author: Medved
Actually CWA do control the output current only, but they do provide quite good line regulation (so compensate out line voltage fluctuations).
The name "constant wattage" came from constant power to lamp with specified, accurate arc voltage (= MV's at the time these ballast were introduced), where the only variable is the mains voltage. This is implemented by regulating the current. In the today's perspective of lamps with the arc voltage dependent on the tube temperature the term "constant wattage" become quite misleading.
