Author Topic: F30T8 CW life test  (Read 2996 times)
Powell
F30T8 CW life test « on: January 19, 2012, 07:32:10 PM » Author: Powell
I got one at Lowes last night and put it in my single lamp rapid start fixture and it did start. I HAD the 50's GE "Standard Cool White" in there. It, when new would not light in it, but I had put it in the lag side of my 2 lamp RS fixture with a T12 in the other side and it lit. So as it amassed a good many hours it would light. I a going to see how this works out. I could NEVER get any of my "NEW" F30T8 Duro Test Optima 50s to light on this unit. I rigged a way where I could I used some very thin speaker wire ( the ones with one wire in each wire) and hooked it up to one side, and gave it a boost with a 12 volt Gel battery. That's cheating.
The GE lamp was made in Hungary. I will report back on what transpires...whatever year that is...... ;D :D
Addition:  When should I see any aging on the ends ?
« Last Edit: January 24, 2012, 09:41:41 PM by Powell » Logged
NNNN!
Powell
Re: F30T8 CW life test « Reply #1 on: March 06, 2012, 06:07:56 PM » Author: Powell
Update. I went to my local ACE hardware and  they had new F30T8 lamps from Indonesia. BOO HISS. Horrible quality. The one I put installed in January, Hungary made looks like I put it in yesterday. I took BOTH of them and put it in my dual 30 watt high power factor fixture in my radio building and to my amazement they lit. It was quite a bit slow, and a very interesting fade up. Now the test will really tell me something.
NNNN!
Silverliner
Rare white reflector
Re: F30T8 CW life test « Reply #2 on: March 06, 2012, 10:08:34 PM » Author: Silverliner
Yup, the reason you see these indonesia lamps is because the Hungarian GE fluorescent plant is gone, closed last year.
Member of L-G since 2005.
Electrician.
Powell
Re: F30T8 CW life test « Reply #3 on: March 07, 2012, 11:03:10 AM » Author: Powell
That is not bad.  That is very, VERY bad.   The 15 watt Indonesian 15 watt K&B lamp  recently got  is VERY poor quality !!   ??? ??? ??? >:( >:( >:( >:( >:( >:( >:(
NNNN!
Powell
Re: F30T8 CW life test « Reply #4 on: December 10, 2012, 12:26:48 AM » Author: Powell
Update....the Hungarian bulb has substantial brown on one end, and it has done a few thoussand hours more than the Indonesian lamp which has a light tan spot and nice strong end banding on one end.
NNNN!
Re: F30T8 CW life test « Reply #5 on: December 10, 2012, 11:13:23 AM » Author: Ash
They would do that sometimes back when they were named Tungsram
And it is indeed very bad with the Tungsram (GE) factory, they were the last good lamps i seen here
