Author Topic: BANG !!!  (Read 8150 times)
Re: BANG !!! « Reply #15 on: January 17, 2012, 05:42:44 PM » Author: Ash
I seen an electrician get a bang like this with a 2x PL 18W fixture
He installed the new fixture, flipped the switch, BANG bright flash tripped breaker
Reset the breaker, fixture flashing without coming on steady
Opened the fixture with the power on to look inside
The fixture was wired incorrectly from the factory - When power connected to the terminal block, 1 PL was directly across the mains and 1 with 2 ballasts in series
Now the REALLY weird part : The PL that banged with diret connection to mains, did light dimly and unstable (like cold cathode discharge) IN THE PL TUBE when connected to the mains again without ballast, though when shaked you could hear something rattling inside - probably the starter glow bottle loose after its wires fused, or it just exploded. If the PL tube did have small discharge without any ballast in series with it, how this discharge sustained without going bang again ? O_o
The other PL on 2 ballasts in series was just flashing as the lamp was not keping on or the starter was not going off after striking
Re: BANG !!! « Reply #16 on: January 18, 2012, 02:43:49 AM » Author: Medved
The electron emission was limited by the saturated emission of the cold makeshift electrode (from remains of the electrode assembly). As the discharge was too weak, it did not heat it up.
The same discharge happen in many tubes without starter - you have very small current, so nearly o voltage drop across the ballast, so for the small current technically the same situation as direct connection to the mains.
But this state is heavily unstable - the electrode may form a hot spot (when there is no ballasting impedance => BANG) or the discharge cease (= darkness), so that is why this operating mode is practically unusable.
DieselNut
John
Re: BANG !!! « Reply #17 on: February 17, 2012, 02:15:57 PM » Author: DieselNut
@ Powell, does your desk lamp have was paper capacitors wired across the "starter" switch?  I have one that the tube glowed continuously like you mentioned and the trouble was a shorted wax paper cap.  I cut it out and it works fine now.  Mine is a two tube fixture, with two choke ballasts and two "push, hold, release" switches.
Preheat Fluorescents forever!
Powell
Re: BANG !!! « Reply #18 on: February 17, 2012, 02:37:24 PM » Author: Powell
No. In fact I have never seen that. If I DID, I would replace the paper capacitor with a ceramic one.
NNNN!
Bulbman256
Mad Max
Bulbman256
Re: BANG !!! « Reply #19 on: June 09, 2021, 08:26:43 PM » Author: Bulbman256
Off topic, but what guests viewing this? Man bots are weird here. ::)
