September 28, 2024, 09:30:52 PM
Modern
Lithonia 100w H38 MV vapor bulb pros and cons
Topic: Lithonia 100w H38 MV vapor bulb pros and cons (Read 3573 times)
Lightguy
« on: September 25, 2011, 04:33:12 PM »
Lightguy
These are the pros and the cons of the lithonia 100w mercury vapor bulb.
Pros:The bulb is very bright and is easy to install in 100W Lithonia MV fixtures.
Cons:If the bulb gets a scratch ,it must be disposed.
The bulb must be turned off at least once a week according to the box instructons.
If you want this bulb go to your local home depot store in the security and area lighting aisle.
N.A.
paintballer22
120V/240V 60hz
Re: Lithonia 100w H38 MV vapor bulb pros and cons
« Reply #1 on: September 25, 2011, 05:58:24 PM »
paintballer22
In the home depot I go to I seen the Philips 100w A-21 and ED shaped ones but not the lithonia ones.They only had 65w fluorescent and 70w MH in the security and area lighting aisle
Lightguy
« Reply #2 on: September 25, 2011, 08:44:48 PM »
Lightguy
Usually I see them in the area with Lithonia bucket lights.There avaliable with the following bulbs:
and
sold seprately
N.A.
paintballer22
120V/240V 60hz
« Reply #3 on: September 25, 2011, 09:44:44 PM »
paintballer22
I was looking at the 50w MH entry lamp at Lowe's. I mite go back and get one for the fun of it.
Lightguy
« Reply #4 on: September 26, 2011, 09:11:19 PM »
Lightguy
Thats good to hear.
N.A.
« Reply #5 on: September 27, 2011, 03:26:14 AM »
The instructions about shutting off once a week if burned 24/7 are on all mercury vapor and metal halide lamp packages, and the warning about disposing of if the lamp is scratched is on all HID lamp packages.
Lightguy
« Reply #6 on: September 27, 2011, 10:10:10 PM »
Lightguy
Thanks for letting me know.
N.A.
© 2005-2024 Lighting-Gallery.net
