Author Topic: How to measure lamp voltage/current on HF ballast?  (Read 9634 times)
Nisei
Re: How to measure lamp voltage/current on HF ballast? « Reply #15 on: January 19, 2022, 07:28:56 PM » Author: Nisei
Thanks Ria
Well I'll just have to trust the specs on the label then and hope it's keeping current between 0.8 and 0.85A
It is the cheapest way to drive a 90W and it's not like I'm running it for hours on end.
John
Re: How to measure lamp voltage/current on HF ballast? « Reply #16 on: January 19, 2022, 07:32:09 PM » Author: Rommie
Correct current for a 90W is nearer 0.9A but 0.85 is close enough. Lamp voltage when fully run up should be 110-112V but remember that a SOX lamp's voltage will rise initially during warmup before dropping down to the normal running level.
By the way, to get the best lamp life, it's always best to run it for a few hours, and not to switch it more than once every 24 hours. I usually run mine for 4 or 5 hours, but I only use magnetic ballasts so it's easy to monitor voltage and current. The only time I tried an electronic ballast supposedly designed for SOX it under-ran it horribly.
« Last Edit: January 19, 2022, 07:36:11 PM by Rommie » Logged
Nisei
Re: How to measure lamp voltage/current on HF ballast? « Reply #17 on: January 19, 2022, 09:16:48 PM » Author: Nisei
Thanks again
But where does the 0.9A come from?
The official Philips specsheet says 0.82A
John
Re: How to measure lamp voltage/current on HF ballast? « Reply #18 on: January 20, 2022, 08:40:08 AM » Author: Rommie
I just looked that up, and you're right, but the general rule has always been 0.6A for up to 55W and 0.9A for over 55W. The voltage specified seems a little different as well  :wndr:
« Last Edit: January 20, 2022, 08:46:46 AM by Rommie » Logged
Nisei
Re: How to measure lamp voltage/current on HF ballast? « Reply #19 on: January 20, 2022, 02:56:42 PM » Author: Nisei
No you were right about the voltage, it's 112V for the 90W
I've made a combined PDF file of all the main pages of the whole SOX series.
Perhaps comes in handy for quick reference.
You can get it here: Click
« Last Edit: January 20, 2022, 03:06:38 PM by Nisei » Logged
John
Re: How to measure lamp voltage/current on HF ballast? « Reply #20 on: January 20, 2022, 02:58:23 PM » Author: Rommie
Thanks, that will be useful. I had some of the Philips data sheets, but not all of them  :lps: :lps: :lps:
Nisei
Re: How to measure lamp voltage/current on HF ballast? « Reply #21 on: January 20, 2022, 03:02:18 PM » Author: Nisei
Sorry, removed the link because there was 1 page in Dutch (psg 35W)
I'll rectify it and post again in 5 minutes.
John
