Author Topic: Cleaning crystallization (metal oxides ?) from glass  (Read 3012 times)
Cleaning crystallization (metal oxides ?) from glass « on: August 10, 2011, 02:49:17 PM » Author: Ash
The HPS floodlights i got have some kind of crystallization on the inside of the glass
It is white, so i suppose it contains aluminum oxide from the reflector. It also has in places stains of rust. It happened probably from a lot of times that water got qaccumulated on the inside of the glass and then dried up by the lamp
How can such layer be cleaned off ?
http://www.lighting-gallery.net/gallery/displayimage.php?pos=-57172
SeanB~1
Re: Cleaning crystallization (metal oxides ?) from glass « Reply #1 on: August 12, 2011, 02:16:33 PM » Author: SeanB~1
Try initially window cleaner. If that does not remove it try using white vinegar on a cloth, alternating with a solution of baking soda. To remove the rust stains wipe with a cloth soaked in Coca Cola, it will remove the rust. Rinse well with clean water afterwards.
