Powell
I remember seeing F96T8( I don't think they were T6...although the F42T6 is still around ) 4 lamp fixtures in Artlite in Atlanta. Black ended bulbs. I wonder when they were discontinued ??
Powell
NNNN!
Silverliner
Rare white reflector
The F96T8 lamps are still made today! I see them in use once in a while around here.
Member of L-G since 2005.
Electrician.
Powell
I mean the ORIGINAL ones. You can't use the new ones on a magnetic ballast.....well you can, but you won't like the results...... Powell
NNNN!
Silverliner
Yep I mean the old F96T8/CW lamps that are 50-51w at 200mA. The modern ones do work, but are a little different they are 255mA.
Electrician.
DimBulb
I remember seeing T8 lamps installed in an F96T12 fixture located in a supermarket back in the 1970s. They were pulsating and didn't seem to like the T12 ballast.
My very first word was LIGHT!
Silverliner
I have seen the same thing! Pulsating means the lamps are overdriven.
Electrician.
I came across one of those old-style T8 blackender slimlines last year. and posted a pic here too
I came across one of those old-style T8 blackender slimlines earlier this year. and posted a pic here too
Powell
Will these work on the solid state ballasts?
Powell
NNNN!
I only tested it on a magnetic T12 ballast (which the ballast didn't like too much until the lamp warmed up LOL) I could try on a electronic sometime I think someone here said it will work!
toomanybulbs
so when were the slimlines introduced? i helped fix some 60's freezer cases that had t8 slimlines in it.
Silverliner
Everyone, yes you can use a 50w 200ma F96T8 lamp on a 59w slimline F96T8 ballast, the 200ma lamp is actually designed to operate anywhere between 100-300ma. Slimline lamps were introduced in the 40s.
Electrician.
