Author Topic: Voluntary Recall of "Philips" SL Electronic Prismatic Light Bulbs (12.2002)  (Read 3394 times)
Kappa7
Voluntary Recall of "Philips" SL Electronic Prismatic Light Bulbs (12.2002) « on: March 11, 2011, 06:47:45 PM » Author: Kappa7
See http://www.consumer.org.hk/website/ws_en/consumer_alerts/recalls_and_alerts/2002120401.html
These had the same shape of the third generation of SL lamps, but with electronic ballast.
Re: Voluntary Recall of "Philips" SL Electronic Prismatic Light Bulbs (12.2002) « Reply #1 on: March 12, 2011, 03:09:37 AM » Author: dor123
I had one of these lamps in the past.
I don't see a reason to stop using these lamps because of this. This isn't dangerous.
Simply the SL-E Prismatics that manufactured between January 2000 to April 2001, have a bad gluing of the prismatic cover (My Philips SL-E Prismatic had a plastic cover) to the plastic mount, causing the cover to detach from the lamp.
The lamp can be operated without problems and risks also without the cover (It will be then simply a tubular CFL with 3 U tubes).
Lampwizard
Re: Voluntary Recall of "Philips" SL Electronic Prismatic Light Bulbs (12.2002) « Reply #2 on: March 13, 2011, 05:36:17 PM » Author: Lampwizard
Philips China should have copied over the Philips Europe shell design from the good, old electromagnetic version. No glue would have been needed and lamps would have lasted longer...
Philips colour 27: best fluorescent tube colour.
