January 05, 2025, 12:39:41 AM
Videos
My new PLL batten fitting..:)
Topic: My new PLL batten fitting..:) (Read 4083 times)
imj
« on: February 20, 2011, 01:29:13 AM »
Author: imj
http://www.youtube.com/watch?v=q1QPy2Tb37U
I like this because of the diffuser and it's using a 36w PLL lamp. This original sate it is in could use an upgrade. Changing it to magnetic preheat start and tube colour to CoolWhite 4000K I also want to change the tube clips which are metal and are too tight so it scratches the tube so it will be plastic type if I can find those.
IMJ
Re: My new PLL batten fitting..:)
« Reply #1 on: February 20, 2011, 05:38:00 AM »
I would stay with metal clips, plastic ones degrade (by light and heat exposure) and become very fragile after few months...
imj
« Reply #2 on: February 20, 2011, 08:56:50 AM »
Author: imj
I was thinking that too but still the clip has to be replaced because it is quite rusted I have removed the tube after some struggle and replaced the electronic ballast with a magnetic ballast and starter..
http://www.youtube.com/watch?v=Vr_1oHEL_TM
http://www.youtube.com/watch?v=JTNk641hrKE
IMJ
Last Edit: February 20, 2011, 09:43:19 AM by imj
Michael
« Reply #3 on: February 20, 2011, 11:06:55 AM »
Michael
You should use metalclips made of stainless steel. Vossloh-Schwabe is making them for instant...
imj
« Reply #4 on: February 20, 2011, 11:53:53 AM »
Author: imj
I hope it is by them when I get it at the shop tomorrow don't want another china crap that came with this. I have opened up the electronic ballast
http://www.youtube.com/watch?v=fPuHAc4M85s
looks like they made cutbacks on some components.
imj
« Reply #5 on: February 22, 2011, 05:08:50 AM »
Author: imj
A bit of update..I am unable to get the clip for the tube the shops here say they don't sell the clip..
. I will have to spray paint the old one with white gloss paint and a clear overcoat paint.
IMJ
« Reply #6 on: February 22, 2011, 12:30:25 PM »
Clean the old clip from all old paint and mainly rust (sandpaper would do the job) and then put a heat-shrink tube sleeve over it. Only if you expect outdoor (i mean out of the living place - so or humid or with changing temperatures) operation, put an protective paint on it before the sleeve.
This sleeve would then protect the tube from scratches and possible glass electrolysis problems (if the clip would be electrically connected to the grounded fitting).
If this sleeve become fragile over time, i would be of no problem, as it is the metal inside providing the mechanical strength...
imj
« Reply #7 on: February 22, 2011, 07:57:08 PM »
Author: imj
Yeah I din't think of the heat shrink sleeving...
