Author Topic: How Eltam's Perfekt-Start ballast for F40T12s works (After a brief turn off)  (Read 3851 times)
How Eltam's Perfekt-Start ballast for F40T12s works (After a brief turn off) « on: November 17, 2010, 01:03:06 AM » Author: dor123
http://www.youtube.com/watch?v=a-v8hWZq_CE
The Perfekt-Start operates the upper lamp which is T12 of 40W.
The lower lamp is a T8 of 36W that also operated from a T12 40W Perfekt-Start ballast (This is why the lamp don't works), makes me easy to show you the operation of the ballast.
I bet that you willn't recognize this behavior as that of a typical rapidstart, quickstart or semi-resonant start.
« Last Edit: June 04, 2011, 12:00:42 PM by dor123 » Logged
SuperSix
ATL P42STUFF supersix94
Re: How Eltam's Rapidstart ballast for F40T12s works (After a brief turn off) « Reply #1 on: December 02, 2010, 04:04:25 AM » Author: SuperSix
It just looks more like switchstart with a half dead starter. Rapid start should restrike the lamps almost instantly but you can clearly see that when you switch the light back on no cathode heating occurs for quite some time.
Re: How Eltam's Rapidstart ballast for F40T12s works (After a brief turn off) « Reply #2 on: December 02, 2010, 04:55:09 AM » Author: dor123
@Eliot_240: See how this rapidstart operates the lamp after a long period of turning off (Equivalent to initial turning on the lamps)
http://www.youtube.com/watch?v=iq7SfcGr998
Not different then a switchstart with an electronic starter (Like the "Pulstarter").
« Last Edit: May 02, 2011, 09:07:31 AM by dor123 » Logged
Re: How Eltam's Rapidstart ballast for F40T12s works (After a brief turn off) « Reply #3 on: May 02, 2011, 12:36:04 PM » Author: Medved
In my eyes this is programmed startof an electronic starter: Heating power provided for defined time and then an ignition. And the timer is reset at (even very short) power OFF.
The Philips S10E starters i bought recently behave exactly in this way...
Re: How Eltam's Rapidstart ballast for F40T12s works (After a brief turn off) « Reply #4 on: May 02, 2011, 01:33:05 PM » Author: dor123
@Medved: This post wasn't active for a long time, and during it, i discovered that these >30 years old ballasts aren't rapidstarts but Perfek-Start ballasts.
See here for more information.
