Author Topic: Can You Run a MH Bulbs On A HPS Ballast?  (Read 6881 times)
Eleco_SR304
Aleksander L.
Can You Run a MH Bulbs On A HPS Ballast? « on: April 13, 2025, 01:47:13 PM » Author: Eleco_SR304
Is It possible to make a MH bulb work on a HPS ballast?
Polish photographer of English streetlights, Rugby, well of course Polish fixtures as well.
I use a Nikon Coolpix P510 42x Optical zoom (16.1 Megapixels) camera to photograph them.
Re: Can You Run a MH Bulbs On A HPS Ballast? « Reply #1 on: April 13, 2025, 02:03:18 PM » Author: dor123
Yes. All CMH lamps and compact QMH lamps runs on HPS gear, and also some 250W and 400W MH lamps like the Philips HPI Plus, and Osram HQI-T 250W/D and Osram HQI-BT 400W/D.
Re: Can You Run a MH Bulbs On A HPS Ballast? « Reply #2 on: April 13, 2025, 04:00:29 PM » Author: WorldwideHIDCollectorUSA
From what I understand, many European pulse start metal halide lamps were designed to run on high pressure sodium ballasts in the first place, but I understand that a higher voltage ignitor is generally necessary to run them unless the lamps are intended as a direct retrofit lamp such as the Philips CDO ceramic metal halide lamps or Venture’s Whitelux lamps.
Interestingly, I am aware that Venture Lighting manufactured some low wattage high pressure sodium to metal halide retrofit kits that were supplied with both a lamp and an ignitor.
However, I understand that there are some European metal halide lamps that are designed to operate on lower current mercury vapor ballasts in conjunction with an added ignitor. Those lamps include Osram’s HQI N/SI probe start metal halide lamps, Venture’s “EURO” probe start metal halide lamps, some models of Venture’s “Uni-Form” pulse start metal halide lamps, plus GE/Tungsram’s high CRI Kolorarc pulse start metal halide lamps. Those types of metal halide lamps are often overdriven on same wattage high pressure sodium ballasts because standard high pressure sodium lamps usually draw more current than same wattage mercury vapor lamps.
« Last Edit: April 13, 2025, 04:07:39 PM by WorldwideHIDCollectorUSA » Logged
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Can You Run a MH Bulbs On A HPS Ballast? « Reply #3 on: April 14, 2025, 12:22:46 AM » Author: LightsAreBright27
Even most ballast say 'HPS/MH' in the print.
245v 50Hz
Cfl3028
@electrojazz2819
Re: Can You Run a MH Bulbs On A HPS Ballast? « Reply #4 on: October 04, 2025, 03:49:04 AM » Author: Cfl3028
I have a used Holophane RSL Street light that is 250w High pressure sodium. However, it came with a 250w probe start Metal Halide lamp installed! The lamp appeared to have been ran in the fixture due to some arctube wear, so I decided to fire it up with that lamp. It actually started, warmed up, and ran pretty well, with very little flickering at full brightness. You'd almost think it was electronic ballasted, I was shocked.
The ballast is a standard High Factor 250w HPS magnetic ballast with single tap 120V, and there is no mention of it being able to run probe start MH of the same wattage. American pulse start Halide lamps might require a higher starting voltage than probe start.
Enthusiast of all things Preheat fluorescent, HID, and halogen lighting
Re: Can You Run a MH Bulbs On A HPS Ballast? « Reply #5 on: October 04, 2025, 06:24:56 AM » Author: RRK
But what surprises you?
In that case, it can with some minor overpowering of the lamp.
