Author Topic: Cars with neon tubes as indicators  (Read 688 times)
LightsAreBright27
Cheap LED Assassin
Cars with neon tubes as indicators « on: April 08, 2025, 07:12:50 AM » Author: LightsAreBright27
I've been doing research to find cars with neon or ccfl lights. I just found out that the BMW Z8 tail lights and turn indicators are neon. Apparently, BMW claims that the neon tubing would last as long as the car itself.
245v 50Hz
Re: Cars with neon tubes as indicators « Reply #1 on: April 08, 2025, 08:09:17 AM » Author: Medved
It is the same claim as was done with HID front lights and also with all the LED lights.
And it is the same claim as "the transmission oil has lifetime over the whole car life so it does not be changed".
But in realty their definition of "car lifetime" is it just barely survives the factory warranty...
Re: Cars with neon tubes as indicators « Reply #2 on: April 08, 2025, 03:01:24 PM » Author: RRK
You are too harsh with these. While HID headlights may have a limited life, properly filled neons may really last into tens of thousands hours, that's more than enough for the life of typical car.
I have a car neon aux stop light, German made by Hella, from the times 'before LEDs' ;)
Probably worth of posting a picture here. A thin custom neon tube with quite sophisticated driver circuit in use.
yuandrew
Re: Cars with neon tubes as indicators « Reply #3 on: April 09, 2025, 02:34:23 PM » Author: yuandrew
1997-1998 Lincoln Mark VIII
Re: Cars with neon tubes as indicators « Reply #4 on: April 10, 2025, 02:20:47 AM » Author: Medved
From that metrics the LED's should have really unlimited life, order of magnitude longer than the car. And for most functions incandescents could be designed to have "way longer then the car" lifetime as well, at the expense of the power requirements.
The problem is, the cold cathode discharges require extra complex circuitry within the light, which in theory should have unlimited life too, but in real life it gets extremely easily damaged, mainly by the humidity. Cause could be even a small break in the light assembly casing, allowing moisture in. And the problem is, the materials normally used for these casings just has limited life and are getting brittle pretty fast.
And then the cold cathode discharges suffer the most, because they need high voltage supply there, which makes the electronics really extremely sensitive to even very small amount of moisture ingress.
Lampwizard
Re: Cars with neon tubes as indicators « Reply #5 on: April 18, 2025, 04:20:07 PM » Author: Lampwizard
I had that aftermarket Hella third brakelight in the neon version. One out of three times I took seconds to ignite. Not exactly what you want regarding a brake light!
Philips colour 27: best fluorescent tube colour.
Re: Cars with neon tubes as indicators « Reply #6 on: Today at 12:18:17 AM » Author: icefoglights
The same neon 3rd brake light was used in the 1995-1997 Ford Explorer.
