Author Topic: Is SOX HID or Fluorescent  (Read 1336 times)
Eleco_SR304
MV in 2025!!!
Is SOX HID or Fluorescent « on: April 03, 2025, 02:48:29 AM » Author: Eleco_SR304
SOX has been always confusing me if it's HID or Fluorescent. I'd say they're both but it's probably one of these two options.
Questions why I think it's HID or Fluorescent:
1) SOX uses a Discharge tube, just like most of HID bulbs do
2) SOX is literally as long as fluorescent tubes and most of fluorescent lights are long
So, any clue if SOX is HID or Fluorescent?
Usually I collect bulbs (Mostly LED) and some HID ones. I also own a couple of streetlights, but most are made in Poland.
However, I mostly prefer SOX bulbs. LED bulbs in their efficacy will never beat SOX bulbs, in my opinion.
Baked bagel 11
Tom
Re: Is SOX HID or Fluorescent « Reply #1 on: April 03, 2025, 02:56:39 AM » Author: Baked bagel 11
Additionally, SOX is at lower pressures, like fluorescent. HPS for example is at much higher pressures.
Re: Is SOX HID or Fluorescent « Reply #2 on: April 03, 2025, 04:07:17 AM » Author: dor123
Low pressure sodium plasma covers the entire arctube. Even low pressure mercury plasma is more constricted than sodium plasma, and is still not an arc.
Only MV, HPS and MH lamps uses high intensity electric arcs, so considered HID lamps.
Re: Is SOX HID or Fluorescent « Reply #3 on: April 03, 2025, 04:09:05 AM » Author: RRK
Neither.
No fluorescence is in use and not high intensity arc :)
Lamp behavior, physical parameters and drive requirement are somewhat close to fluorescent tubes, sure.
« Last Edit: April 03, 2025, 04:11:24 AM by RRK » Logged
LightsoftheWest
SRP for life.
streetlightian
Re: Is SOX HID or Fluorescent « Reply #4 on: April 03, 2025, 05:16:34 AM » Author: LightsoftheWest
I guess it could be called low intensity discharge (LID).
Re: Is SOX HID or Fluorescent « Reply #5 on: April 05, 2025, 02:36:40 PM » Author: WorldwideHIDCollectorUSA
I also think that fluorescent lamps and germicidal low pressure mercury vapor lamps can also belong in this “low intensity discharge” lamp category too. In general, I understand that fluorescent, germicidal low pressure mercury vapor, and low pressure sodium lamps, and neon lamps are all “low pressure gas discharge” lamps while HID lamps such as high pressure sodium, metal halide, and mercury vapor are all “high pressure gas discharge” lamps.
LightsAreBright27
Cheap LED Assassin
Re: Is SOX HID or Fluorescent « Reply #6 on: April 06, 2025, 03:22:35 AM » Author: LightsAreBright27
I consider germicidal lamps, neon tubes and LPS more similar to fluorescents, just without the phosphor. If only lamps with phosphor were considered fluorescent, many MVs will also be considered fluorescent.
245v 50Hz
Re: Is SOX HID or Fluorescent « Reply #7 on: April 06, 2025, 03:28:49 AM » Author: dor123
But neon lamps aren't hot cathodes like germicidal and LPS lamps.
Neon are usually either glow discharge or cold cathodes discharge. The rest are hot cathodes discharge, even if not considered an arc.
LightsAreBright27
Cheap LED Assassin
Re: Is SOX HID or Fluorescent « Reply #8 on: April 06, 2025, 08:57:49 AM » Author: LightsAreBright27
Even CCFLs are cold cathode, but have phosphor coatings.
245v 50Hz
Re: Is SOX HID or Fluorescent « Reply #9 on: April 06, 2025, 03:58:36 PM » Author: Olav
I can only recommend reading one of these books:
books relating to the technology of electric light sources
Incidentally, you can also read this in small sections.
The books are well written and easy to understand.
It would save some nonsensical posts.
Best regards
Silverliner
Rare white reflector
Re: Is SOX HID or Fluorescent « Reply #10 on: April 08, 2025, 01:16:22 AM » Author: Silverliner
SOX is low pressure discharge. Clean and simple.
Member of L-G since 2005.
Electrician.
Re: Is SOX HID or Fluorescent « Reply #11 on: April 08, 2025, 01:20:28 AM » Author: WorldwideHIDCollectorUSA
Same with fluorescent and germicidal lamps.
