Multisubject
All lights are created equal
I am interested in getting an HPS retrofit lamp because I don’t have any HPS ballasts in my (very limited) collection but still want to be able to see HPS light. 1: Efficiency I can only assume that the efficiency of retrofit lamps is less than the “real thing”, is this true? 2: Compatibility What brands are there? What types of ballasts are they compatible with? 3: Best choice for me I have only 2 ballasts, one 100W HX pulse/probe start MH ballast and one 400W CWA probe start MH ballast. What do you think would be the best lamp option for me? Thanks again for your help!
Neon-argon filled HPS retrofit lamps, aren't suitable for CWA ballasts, as these ballasts can run them at very high currents, leading to very short lamp life, because of the lamps very high rate of lamp voltage rise during life, which isn't compliant to CWA ballasts. If you want a HPS retrofit lamp for CWA ballast, you need a retrofit HPS lamp with a stable voltage through life like the Philips Retrolux or the EYE SunluxUltra, which are unsaturated HPS lamps that don't cycles at EOL but just glowing mercury color at EOL.
Multisubject
Thanks, do you know if there are any retrofit lamps what will fit a 100W MH ballast? I personally haven’t seen any of that wattage but I may be wrong
Most of the retrofits I know available for the American MV ballasts, are 150W, 210W, 350W and 680W and 980W. There is no retrofit for 100W MV lamps.
Multisubject
Ok, so I guess my only option is a 350W Sunlux Ultra or Retrolux...
If you have a North American 100W M90 pulse start metal halide HX ballast, a standard European 100W high pressure sodium lamp should run perfectly fine as both North American 100W M90 pulse start metal halide lamps and European 100W high pressure sodium lamps have very similar electrical specifications to each other. 100W M90 pulse start metal halide lamps have an operating current of 1.1A and an arc voltage drop of about 100V: https://fusion-lamps.com/wp-content/uploads/sites/4/spec_sheets/TAMCOUSA_DataSheet_928881.pdfEuropean 100W high pressure sodium lamps have an operating current of around 1.2A and an arc voltage drop of 100V: https://www.assets.lighting.philips.com/is/content/PhilipsLighting/comf1612-pss-en_myEven though European 100W high pressure sodium lamps and North American 100W M90 pulse start metal halide lamps have very similar electrical specifications, you will need either an E39 or E40 lampholder for the European high pressure sodium lamp as those lamps almost always use an E40 base while most North American 100W M90 pulse start metal halide lamps use an E26 base, but there are some with an E39 base too and they are less common. Here is an example of a European 100W high pressure sodium lamp running on a North American 100W M90 pulse start metal halide HX ballast: https://www.lighting-gallery.net/gallery/displayimage.php?album=6271&pos=147&pid=186009
« Last Edit: March 22, 2025, 03:13:37 PM by WorldwideHIDCollectorUSA »
Yes. Additionally, the CEW Retro Ace 360W high pressure sodium retrofit lamps are a good option as they are rebranded Philips Retrolux lamps.
Here are some European 100W high pressure sodium lamps I found for cheap: https://www.ebay.com/itm/356530893847https://www.ebay.com/itm/335864733682https://www.ebay.com/itm/356672238421They should work well on 100W M90 pulse start metal halide HX ballasts without any circuit modifications.
« Last Edit: March 22, 2025, 07:28:46 PM by WorldwideHIDCollectorUSA »
Multisubject
So these European lamps will just work on US metal halide ballasts?  So why did the US feel the need to specifically make HPS bulbs that require different ballasting? Just to add to the ambiguity?  This is excellent, because I can have one ballast with a mogul socket that can power MV, MH, and HPS (and I can connect the ignitor to a switch so I can disconnect the ignitor while running MV). I am going to make a separate post in the forum just to get the specifics of this. Thank you so much!!!
« Last Edit: March 24, 2025, 10:04:11 AM by Multisubject »
As far as I know, European low wattage high pressure sodium lamps should work just fine on North American low wattage pulse start metal halide HX ballasts although there are some minor differences in electrical specifications across same wattage lamps. From what I know, European 35W high pressure sodium runs at 90V, 0.49A, European 50W high pressure sodium runs at 85V, 0.76A, European 70W high pressure sodium runs at 90V, 0.98A, European 100W high pressure sodium runs at 100V, 1.2A, and European 150W high pressure sodium runs at 100V, 1.8A: http://www.mega-ex.com/product_general/Sylvania%20Lighting/Sylvania%20Lighting2/Sylvania%20lamps.pdfIn addition, North American low wattage pulse start metal halide lamps have similar electrical characteristics compared to European low wattage high pressure sodium lamps. 35W M130 pulse start metal halide lamps run at 85V, 0.53A, 50W M110 pulse start metal halide lamps run at 85V, 0.66A, 70W M98 pulse start metal halide lamps run at 90V, 0.88A, 100W M90 pulse start metal halide lamps run at 100V, 1.1A, and 150W M102 pulse start metal halide lamps run at 95V, 1.8A. Specs can be shown here: https://www.lighting-gallery.net/index.php?topic=117.msg83943#msg83943In short, you should be able to safely run low wattage European high pressure sodium lamps on low wattage North American pulse start metal halide HX ballasts. Some lamps might be underdriven or overdriven a little bit, but should be within tolerable levels.
I believe the main reason the US standardized on the 55v arctube HPS for the 35w to 150w range was so they could run them off cheaper reactor ballasts on 120v. This allowed for relatively low cost and compact HPS fixtures for the residential market in the 80s and 90s. There was also an attempt to create a low voltage MV lamp that could run off a reactor ballast on 120v but it had limited use and success.
150w is a interesting case as you have the S55 which is a 55v lamp and the S56 which is a 100v lamp and is electrically compatible with 150w PSMH (there were ballasts that listed both lamp types)
In Europe the line voltage is higher so they didn't need a special line of HPS lamps like the US did.
Multisubject
I had no idea American S56 was compatible with MH ballasts! Too bad I don’t have any 150W gear.
1: Efficiency
2: Compatibility
Additionally in terms of efficiency, the early penning start retrofit lamps designed for mercury vapor ballasts have a rather low luminous efficacy while later versions of high pressure sodium retrofit lamps for mercury vapor ballasts have a luminous efficacy close to that of normal high pressure sodium lamps.
