Author Topic: Need help to find label of this ballast for wiring  (Read 467 times)
LightsAreBright27
Cheap LED Assassin
https://www.youtube.com/@
Need help to find label of this ballast for wiring « on: March 16, 2025, 08:54:41 AM » Author: LightsAreBright27
I found this ballast along with a frame in an 80w lantern head (broken) and want to use it. But the label on this ballast is disintegrating. Can anyone show a picture of the label from a similar ballast? I need it for future reference when replacing the old, damaged ignitor and capacitor.
From what I can read- philips 80w MV ballast (HPL-N)
« Last Edit: March 16, 2025, 08:58:52 AM by LightsAreBright27 » Logged
245v 50Hz
Re: Need help to find label of this ballast for wiring « Reply #1 on: March 17, 2025, 01:06:41 AM » Author: RRK
What ignitor do you mean? This is a MV choke! Ballast label is still pretty much intelligible IMHO - this is a just a simple choke with 3 taps intended for 200-220-240V operation and an optional PFC capacitor across the line. That's it.
LightsAreBright27
Cheap LED Assassin
Re: Need help to find label of this ballast for wiring « Reply #2 on: March 17, 2025, 06:15:52 AM » Author: LightsAreBright27
Oh sorry! There was an empty plastic can inside the fixture, so I thought there was an ignitor. I think the fixture was retrofitted later on, and this assembly was thrown inside (the fixture was huge, you could store 5 ballasts and lamps inside). The 'ignitor' must have come from the HPS retrofit.
245v 50Hz
