Author Topic: 1962 Circular Fluorescent lamp with unusual bases  (Read 39383 times)
Em62Kent
1962 Circular Fluorescent lamp with unusual bases « on: January 12, 2025, 03:49:10 PM » Author: Em62Kent
Hello there. I have had this lamp for almost a year now. It is a very old circular glass fluorescent light fixture dating back to 1962. The ballast has seemingly been replaced. However it has a very unusual style of bulb. It has a 65w/80w circular lamp with two separate G13 bases instead of a typical G10q base. It is also T12 in width which is very unusual. I’ve never seen this sort of lamp before and I can’t find any information about it. If anyone has any information about this lamp please let me know as it would be very helpful.
LightBulbFun
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #1 on: January 12, 2025, 06:02:12 PM » Author: LightBulbFun
Awesome find! I have been looking for one of those for years and years now! theres a few collectors who have examples, but I have never been able to find one sadly
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-76898
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-173575
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-183835
there is sadly not much information out there about them exactly, the earliest examples had Bayonet end caps but most have bipin caps like yours, I was told many many years ago that the coal-board used these tubes in some application or another, but I have nothing to substantiate that, they are in general quite the mysterious tube
the company Bright Light Lamps or Long Lamps (not sure if they where 1 and the same or 2 separate companies) specialised in making custom/weird fluorescent tubes :)
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-204487
they also made another famous but just as mysterious "W" tube
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-137103
« Last Edit: January 12, 2025, 07:15:21 PM by LightBulbFun » Logged
Em62Kent
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #2 on: January 13, 2025, 02:52:43 AM » Author: Em62Kent
Thank you this is really helpful. The tube in this lamp is original the 60s and still works perfectly. Hopefully it’ll work for another 30 years!
UChBXesrxSalDTp79uMtfDvA
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #3 on: January 17, 2025, 05:36:22 PM » Author: WorldwideHIDCollectorUSA
I highly recommend only running this fixture occasionally due to the extreme rarity of these circular fluorescent lamps.
Em62Kent
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #4 on: September 28, 2025, 11:34:54 AM » Author: Em62Kent
As of today, the lamp in the fixture is working fine without any issues. Unfortunately the fixture is located in the downstairs corridor of my home right beside the stairs and it is used every day out of my control. What I am planning to do is to replace the lamp that is currently in the fixture with a 60W circline as this is compatible with the new ballast I fitted earlier this year, however I don’t know when I will be able to do this. Also, since the 80s, circlines have become much less popular in the UK than they were anywhere else most likely due to the 2D lamp, invented by Thorn in 1981, being favoured. They are also pretty hard to find at a reasonable cost. I will try to replace the lamp as soon as I can, but hopefully by the time I have the parts to replace it (I also need a new base for it), the old lamp will still work.
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #5 on: September 29, 2025, 02:04:56 PM » Author: Ash
Can you put in there a 40W circline and ballast ? (Dont remove the 65W ballast, wire it back in once you find a 60W circline)
Em62Kent
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #6 on: September 29, 2025, 02:06:12 PM » Author: Em62Kent
Unfortunately I don’t have a 40W ballast spare at the moment.
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #7 on: September 29, 2025, 02:49:13 PM » Author: Ash
40W LED circline with no ballast ? (Not the greatest lighting, but as a temporary step)
Em62Kent
Re: 1962 Circular Fluorescent lamp with unusual bases « Reply #8 on: September 29, 2025, 05:16:05 PM » Author: Em62Kent
Unfortunately I don’t have this either. I will most likely buy a 60W circline as the new 58W ballast is already there. They are pricey but there is this shop I know of that has all sorts of old fluorescent tubes, and I might go and check there again to see if they have any circlines.
