Author Topic: A way to light fluorescent lamps with completely worn out cathodes  (Read 26342 times)
Laurens
A way to light fluorescent lamps with completely worn out cathodes « on: December 31, 2024, 12:41:56 PM » Author: Laurens
So i just found my personal holy grail - a color 27 (incandescent fluorescent) in the recycle bin. Sadly, the cathodes are completely worn. When it finally lit after many start attempts, the current slowly dropped and after 30 seconds it was gone and started flashing again.
But since cathode failure is pretty common, i've been thinking of a way of powering these things without using the cathodes. A cold cathode discharge is not an option - they run way too hot. I'm a ham radio operator. I've played around with fluorescents before just for fun.
But what if i purposefully hook up a fluorescent tube to the transmitter?
I grabbed a completely fine CW 20w t12 tube (the dead color 27 one is at my new house, my ham radio stuff at my old)  and wrapped some aluminium foil around the ends, taking care that it doesn't contact the end caps or the pins.
I first hooked it up straight to my tuner - no luck, only very faint partial ionisation.
Then i grabbed a little coil i wound a long time ago for a crystal receiver. About 80 turns with a tap at 10. Hooked up the 10 turn tap to my tuner's unbalanced output, the 80 to one side of the tube and GND to the other. It's running on 3500khz.
Video: https://youtu.be/TvPJrV3VSUk
I think a purpose built power oscillator will be able to power the 65w lamp at near full brightness. I will have to figure out screening - with 65w of RF power (currently running 10w from my little yaesu ft-7) and E-fields of many hundreds of volts per meter, i am pretty sure that even with the short wires it will emit a few watts, which is enough to reach all of my country on 3,5MHz.
This may also be a way to dimly light your tubes without any risk on sputtering at all, i reckon.
« Last Edit: December 31, 2024, 12:48:13 PM by Laurens » Logged
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #1 on: December 31, 2024, 06:09:43 PM » Author: RyanF40T12
Thing is, when most fluorescent lamps on electronic ballasts go EoL, they will generally get hot enough that the glass cracks and then you have vacuum loss and they will not light no matter what.
Laurens
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #2 on: December 31, 2024, 06:30:51 PM » Author: Laurens
Not all ballasts are electronic ones, so if you got a worn out one that still got its vacuum, this can be a way to get them to light.
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #3 on: January 01, 2025, 12:50:36 AM » Author: RRK
Yes this works, but beware the glass under the foil gets rather hot and will crack too if you drive the tube hard enough. Ask me how I know )
Happy New Year to everyone here!
« Last Edit: January 01, 2025, 06:46:36 AM by RRK » Logged
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #4 on: January 01, 2025, 12:11:54 PM » Author: RRK
Fortunately or no, no way it gonna happen ;)
Laws of electrodynamics tell for antenna to be efficient it shall be sized comparable to the wavelength, in practice at least lambda/2 dipole or lambda/4 whip across the ground plane. Anything smaller generally just pumps RF energy around the immediate vicinity with nothing radiated further. Your setup may radiate a little, but in the range of milliwatts.
Small antenna for lower SW bands is sure a long term wet dream of radio amateurs, but it is just physically impossible. Many times you can live with an inefficient antenna for reception assuming input stage has low noise and high sensitivity, however it just does not work for transmission when you have to fight with interferences using a real radiated power.
« Last Edit: January 01, 2025, 01:44:14 PM by RRK » Logged
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #5 on: January 01, 2025, 05:56:00 PM » Author: Baked bagel 11
That's a lovely lamp, real shame it's damaged.
Laurens
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #6 on: January 02, 2025, 04:32:59 AM » Author: Laurens
It is! But if i can find a way to get it here, i've been offered an identical lamp by another forums member :)
Probably going to be an interesting train ride, or a 'taxi' ride with another dutch lighting enthousiast.
If i can find a way to get this project to work well enough, i'll probably still keep this one running at a quarter power or something, just to look nice in the corner of a room.
I'll fire up the Yaesu ft101 and put an FT8 signal into it, we'll see how good of an antenna a 65w fluorescent lamp is  :laugh:
I am aware of the limitations. However, i've also noticed that on short wave frequencies, the actual necessary radiated power to notice a signal across a couple hundred kilometers can be extremely small on good days. As in 'I cannot see my power meter deflect' which in my case means less than 100mW into a 1/8 or 1/4 wavelength vertical.
Although efficiency rapidly drops with smaller antennas, i've also heard my own CW signals across several countries with just a wire of 4m long on 80m, running 10w or less. I did use a somewhat proper ground of course.
« Last Edit: January 02, 2025, 04:43:49 AM by Laurens » Logged
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #7 on: January 03, 2025, 01:30:45 AM » Author: RRK
Well, but originally we discussed a possibility of leakage of several *watts* RF out of a fluorescent tube driving circuit @3.5MHz. This just won't happen.
Running QRP some hundreds mW into a large tuned antenna has absolutely nothing to do with this. Also in fact transmitting distance (all other things equal - bandwidth, environmental noise level at receiver endpoint) is about proportional to transmitter field strength, that is antenna voltage, not antenna power. This makes a real difference of transmitting at 500mW and say, 10W much less dramatic. Though radio people love talking Watts )
tigerelectronics
Long live fluorescent!
UCcObKY_XCMIZZOBNWn-PC4A
Re: A way to light fluorescent lamps with completely worn out cathodes « Reply #8 on: May 19, 2025, 05:21:52 AM » Author: tigerelectronics
When I was younger I built a fluorescent tube 12V powered inverter circuit that is based on a self oscillating transformer made from a ferrite rod from an old radio. I wound the transformer myself with a power drill to spin it. It used a 2N3055 or any other decent power rated transistor will also work. This circuit will power tubes that have completely blown kathodes. You won’t get full brightness out of a tube with this circuit unless you increase the number of secondary turns on the transformer , but it drives the tubes at around 50% brightness in standard form. It works by producing a very high frequency high voltage, around 1000 volts but with very low current so it sort of self regulates.
I’ve powered plenty of tubes with blown kathodes using it. And since it drives them at lower power levels, the ends of the tubes won’t get hot enough to crack the glass or anything, the kathode structure which is usually all that remains after a tube has gotten both its kathodes blown, doesn’t even glow red inside the tube.
So yes it is possible to run blown tubes, and I believe in this operating mode they’ll probably keep on working forever unless they get physically damaged. I also suspect the phosphour will eventually wear out so much that the tube becomes super dim. But it works!
If I can find it, I’ll try to post a photo or link to the schematic when I get home from work. I’ll try to remember.
Fluorescent tube hoarder :P
