Author Topic: Fluorescent Light Blackening  (Read 243 times)
Flatbottom
Fluorescent Light Blackening « on: December 23, 2024, 04:29:49 PM » Author: Flatbottom
I have noticed, especially on older fluorescent lights, the blackening is heavier on the non-etch end than the end with the etch (if it blackens at all). Does fluorescent blackening and etch have something related? thanks
RCM442
Re: Fluorescent Light Blackening « Reply #1 on: December 23, 2024, 05:10:27 PM » Author: RCM442
All depends on which side is the "hot" side of the ballast. Etch placement has nothing to do with it.
Administrator #4
LightsAreBright27
Cheap LED Assassin
Re: Fluorescent Light Blackening « Reply #2 on: December 24, 2024, 01:38:51 AM » Author: LightsAreBright27
I once put two lamps in opposite direction, in a dual lamp fixture. In one of them the etch side became darker, while on the other it was the non-etch side. It just depends on how you put the lamp.Newer lamps may have different filament resistance, so may not find the difference between the ballast's sides.
245v 50Hz
Re: Fluorescent Light Blackening « Reply #3 on: December 25, 2024, 03:04:22 AM » Author: Medved
Well, except the modern T5HE/HO tubes, there the etch signalizes the end with the amalgam capsule (and longer "dead end" where the filament is further away from the seal), so in order to insert the tube with correct orientation, yu should follow the instructions on on which side the etch should be.
