Author Topic: Is a diffraction grating effective at analyzing lamp spectra?  (Read 3222 times)
Is a diffraction grating effective at analyzing lamp spectra? « on: November 09, 2024, 09:24:01 PM » Author: WorldwideHIDCollectorUSA
Since I have been reading on here that a fluorescent or phosphor coated mercury vapor lamp’s spectrum is the best way to identify the phosphor being used and for identifying a metal halide lamp’s arc tube chemistry, I have been seeing some sources saying that diffraction gratings are effective at analyzing lamp spectra. In general, are diffraction gratings a good tool for analyzing a lamp’s spectral emissions?
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #1 on: November 09, 2024, 11:20:25 PM » Author: Medved
Why shouldn't they?
Not that difficult to make really colorless (I mean without artifafts like material absorbing some spectral lines or parts of the spectea like the thick  prisms may do), not that difficult to get your hands on for a diy device (CD, DVD,...).
Yes, the spectrum analyzer made of it tends to pass only a little light, but for studying bright sources it is more of an advantage than a disadvantage.
The only problem could be "overtone" ambiguities (the direction where a XX wavelength goes, also the XX/2 and XX/3 go, so UV and violet tends to excite IR and red), but that could be identified by having wider range and comparing those sections where the "result transposition" may happen. Or use filters that restrict the spectra so no such ambiguity may happen anymore.
Laurens
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #2 on: November 10, 2024, 06:38:57 AM » Author: Laurens
A diffraction grating is effective. The Little Garden spectrometer i have, uses a DVD as a diffraction grating.
If you want to make a quantitative analysis, you do need some kind of wavelength calibration. In this case, it's in the Theremino software and you calibrate it on two mercury vapor discharge calibration points.
Indeed, you need to take the 'copies' of the signal into account. This is when you use an infrared-pass filter (if your "infrared" spectrum goes away when you use a pass-filter, it's a copy of the visible spectrum appearing for the 2nd time).
There are enough simple DIY projects to make a little diffraction grating spectroscope and that way you can already distinguish between types of phosphor and roughly figure out what lines there are. In the attachment are the analysis steps i took before i had the spectro*meter*. Take pictures of the spectra you see (i used a very high quality spectroscope), align and compare them with known and trusted sources. In the attachment you can see how i analyzed what was in a small E14 indicator light bulb with a white color.
In this case the first spectrum is a color 33 fluorescent, the one below that the spectrum of the unknown indicator light. Below that, ambient fluorescent light plus a neon indicator light, and all the way down a single neon indicator light. From lining these up, we can conclude that the unknown light bulb contains a mixture of neon and mercury, and is coated with halophosphate phosphors.
Of course, it's much easier to do it with a spectro*meter*. If you can get hold of one, you're best off spending 60 euro for a Little Garden. To a degree you can build it yourself - the hard part of removing the Bayer filter from the webcam is optional. However, if you don't remove the bayer filter, you will get an inconsistent color response. In these pictures you can already see 'red' 'green' and 'blue' color bands in the halophosphate spectrum, while with the eye you can see the complete range of colors. The camera does not interpret them correctly, it just bins them in one of the filter bands.
Still, you'll be able to see the peaks at their correct wavelength, even if the amplitude of the peaks is completely wrong.
« Last Edit: November 10, 2024, 06:42:31 AM by Laurens » Logged
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #3 on: November 10, 2024, 01:42:04 PM » Author: RRK
Yep, diffraction gratings an not only 'useful', but are the base of most modern spectrometers. From a half-toy Little Garden to multi - 1000$$ options from Ocean Optics. Other popular option is a prism.
Little Garden is so much fun for $60, no more need to mess with anything DIY. You get a nice box and the results are generally better!
Some Little garden examples:
That elusive yellow 400W MH lamp from BLV! Finally hunted down a couple, though at a steep price... Note these are Thallium - Sodium - Lithium. Lithium component was not mentioned for these before, though is pretty evident on a spectrogram.
70W purple color MH lamp from BLV. Probably does not like running from electronic ballast, too much pressure, blue indium line is inverted and some continuous spectrum part appears.
35W Elite MH from Philips. Note calcuim 'humps' in deep red, giving the lamp good red rendering and incandescent-like appearance!
6W 930 color Osram from Bari, Italy. No more of these nice tubes :( Good deep red from these...
« Last Edit: November 10, 2024, 01:44:57 PM by RRK » Logged
lights*plus
George Liv Photo
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #4 on: November 26, 2024, 05:25:39 PM » Author: lights*plus
Diffraction gratings are key parts in spectroscopic and spectrographic devices. They are inexpensive compared to a good quality prism, can easily be found in various sizes and number of grooves/mm or lines/inch (depending on desired dispersion strength), and to me they are much easier to use, as the resultant spectrum is a linear dispersion of wavelengths as opposed to logarithmic (or is it geometric?) with a prism.
If you simply use your eyes, you only need to buy a grating.
You hold the grating with your left hand (in its mounted ring or in a 35mm slide) right up against your eye. With your right hand, simply hold a home-made cardboard card with a 1 or 2 mm slit at center, between you and your lamp.
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #5 on: November 27, 2024, 03:55:12 AM » Author: dor123
@RRK: I didn't know you have BLV HIT-T 400W Yellow MH lamp and that it have Li, in additional to Na-Tl, and that your 70W purple MH lamp have huge self-reversing indium line like my 70W 8000K MH lamp.
« Last Edit: November 27, 2024, 05:00:38 AM by dor123 » Logged
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #6 on: November 27, 2024, 10:07:39 AM » Author: RRK
Yep I had to pay steep ~ $65 / piece for yellow lamps, it was painful, but boy these are really rare!! Now i can brag I have all the colors of color MH possible and more, haha)
Indium inversion is common, a little step further with the power and it just turns wideband cold white.
« Last Edit: November 27, 2024, 10:10:59 AM by RRK » Logged
Laurens
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #7 on: November 27, 2024, 11:14:30 AM » Author: Laurens
While this is not a quantitative way to analyse, it's incredibly easy to build a little spectroscope from a piece of cardboard tube, some aluminium foil (or some other way to make a very tiny aperture) and a piece of DVD.
The narrower the aperture slit, the better the resolving power of the spectroscope, but the less light you get. A good idea is to attach a second tube that matches up with the eye hole, so you can shield your eye (or camera) from ambient light.
If you make the aperture very narrow (some make it of two razor blade edges), you can start to distinguish spectrum lines and compare them to known other sources, to find out what elements are used in your lamp.
The piece of DVD needs to be rotated in such a way that you get vertical spectrum lines.
In the picture is the spectrum of an 8w triphosphor fluorescent tube.
Experiment with size, angle and distance of everything.
Re: Is a diffraction grating effective at analyzing lamp spectra? « Reply #8 on: November 27, 2024, 12:32:48 PM » Author: dor123
In the level of the spectrum of your 70W purple MH lamp, I've first seen in my 70W 8000K MH lamp from Aliexpress. My 14000K 70W indium lamp from aliexpress don't have such huge indium inversion: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-221868
And so my Venture MH-DE 70W/UVS/PDX lamp: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-231287
Also: See the color of my BLV HIT-DE 70W Orange MH lamp: https://www.lighting-gallery.net/gallery/displayimage.php?pos=-246191
