Author Topic: Are circline fluorescent lamps good “ring lights” for filming and photography?  (Read 7872 times)
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #15 on: November 05, 2024, 12:45:20 PM » Author: WorldwideHIDCollectorUSA
A good number of magnifiers use 22W T9 circline lamps on manual preheat circuits.
Laurens
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #16 on: November 06, 2024, 02:00:00 PM » Author: Laurens
I got one at work, but it's a conventional with bimetallic starter. I like it :)
sdsw4
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #17 on: November 07, 2024, 01:39:45 AM » Author: sdsw4
Hmm, the guy running the local batteries plus had two packs of 2 FCL/T4 11w circlines. These might actually fit the bill to try on a small camera for OP, unlike trying say a larger FC8T9.
What's a good ballast to run these on? Tried out a WH2-120-C, but it seems to be overdriving by a lot.
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #18 on: November 07, 2024, 01:41:44 AM » Author: WorldwideHIDCollectorUSA
I think a good way to determine this is to know the lamp’s operating current and arc voltage drop and look for a ballast designed to run a lamp that has similar or identical electrical specifications.
From what I have gathered, I think an Advance L-1Q13-TP preheat fluorescent ballast with a FS4 starter might work well, but not sure about that either since I am aware that it probably has a similar operating current to F13T5 fluorescent tubes.
« Last Edit: November 07, 2024, 01:45:07 AM by WorldwideHIDCollectorUSA » Logged
sdsw4
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #19 on: November 07, 2024, 01:53:33 AM » Author: sdsw4
Correction: Finally decided to crack open the kill-a-watt. The Fulham appears to be driving the tube fine, it's pulling 12w. But still instant-start.
Hmm, what's a decent rule-of-thumb to figure out the voltage drop?
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #20 on: November 07, 2024, 01:54:52 AM » Author: WorldwideHIDCollectorUSA
From my experience, I would use the probes of a volt meter and have them touch the lamp’s pins while the lamp is operating.
F40
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #21 on: November 09, 2024, 08:38:10 AM » Author: F40
Only if a Vita-Lite is used and I am not sure if those exist in circline and MAYBE a Philips K&B Soft White but if ur doing black and white photography it shouldn't matter, but either way its best if an electronic ballast is used
Re: Are circline fluorescent lamps good “ring lights” for filming and photography? « Reply #22 on: November 09, 2024, 12:45:38 PM » Author: WorldwideHIDCollectorUSA
From what I know of, Duro Test did make some Vita Lite lamps in 22W T9 and 32W T9 circline fluorescent versions.
Here are some 32W Duro Test Vita Lite circline fluorescent lamps:
https://www.lighting-gallery.net/gallery/displayimage.php?album=search&cat=0&pos=2&pid=65950
