Author Topic: Joslyn help  (Read 257 times)
Baked bagel 11
Tom
Joslyn help « on: Today at 12:39:32 AM » Author: Baked bagel 11
I have just bought a Joslyn head (https://www.ebay.com/itm/235666944676?) (Canopy Jrrt and head Cs3). I was wondering where I could find a jones socket incandescent lamp or pictures of one (out of curiosity). I was also wondering if anyone knew about where I could find a teardrop bowl which would fit the canopy (something like this https://hdl.huntington.org/digital/collection/p16003coll2/id/65395/rec/26 ).
An Aussie collector of the street lights of the world.
fluorescent lover 40
Re: Joslyn help « Reply #1 on: Today at 01:14:25 AM » Author: fluorescent lover 40
The comment you made on rlshieldjr's post here is jones socket for a series incandescent light. That is what you should be looking for.
Good luck finding a glass on its own though. It's far more common to find a complete reflector/glass assembly.
Baked bagel 11
Tom
Re: Joslyn help « Reply #2 on: Today at 01:34:16 AM » Author: Baked bagel 11
Yeah fair enough about the glass, what about photos of the lamps?
Re: Joslyn help « Reply #3 on: Today at 02:04:48 AM » Author: fluorescent lover 40
Here's some photos.
Old Ken-Rad
Philips China
Old big unknown one
A pair of Westys
Another GE
And finally one from your home country.
Baked bagel 11
Tom
Re: Joslyn help « Reply #4 on: Today at 02:07:06 AM » Author: Baked bagel 11
Thanks for that, do you know of any jones type lamp pictures?
Re: Joslyn help « Reply #5 on: Today at 02:13:42 AM » Author: fluorescent lover 40
Those pictures of lamps I linked are series incandescent lamps. The jones socket is the (or the type of) socket that series incandescent street lights used. I could be wrong, but the jones-type is the most common (or even the only type) of series incandescent street lighting socket out there.
Baked bagel 11
Tom
Re: Joslyn help « Reply #6 on: Today at 02:33:33 AM » Author: Baked bagel 11
Apologies for my lack of socket information, is there a specific type of base which would fit into the jones socket (I would imagine a blade like base) or can a mogul just fit into it?
Another question which I have been wondering for some time is, what is the difference between series incandescent and, I would assume, multiple incandescent, and how this determines the type of base used? Do they require the mogul adaptor?
Re: Joslyn help « Reply #7 on: Today at 04:11:49 AM » Author: fluorescent lover 40
The series incandescent lamps have regular mogul base (E40 for that Australian one of course).
Series incandescent lights run off a constant current regulator, with a maintained current. They are wired in series, but with the help of the jones socket, the series circuit can run even if a lamp burns out or is removed. Any problems with a series string can take the entire thing out of service. The lamps are mogul base only (afaik, I haven’t seen a E26/E27 series lamp yet). You can light a series lamp by itself if you can provide the proper voltage and amperage for it.
Multiple is basically standard incandescent street lights wired  in parallel at mains voltage from a normal stepdown transformer. Basically normal incandescent street lights with special street lighting incandescent lamps. They come in medium and mogul base (I don’t know if these were ever available in your country). You can use regular lamps in them if you want to. And as for how they work, well, if one lamp burns out, the rest will stay lit, and any issues with the wiring or a light likely won’t stop the rest of the lights from working.
Baked bagel 11
Tom
Re: Joslyn help « Reply #8 on: Today at 04:49:23 AM » Author: Baked bagel 11
Ahh, that clears everything up now. Thank you very much for being patient and explaining everything! :)
