Author Topic: What version of Windows will work on a '02-'03 Intel Pentium 4  (Read 1988 times)
Caroline
Re: What version of Windows will work on a '02-'03 Intel Pentium 4 « Reply #15 on: October 24, 2024, 08:21:33 PM » Author: Caroline
Which P4? my workshop/basement PC has the 541, bit newer but it's still ancient to run W7 on it, Vista wasn't even considered as it's basically a beta OS that was released on a rush.
I run 2K on it as XP crashes the same way as yours, tries to load but restarts, probably a driver conflict of sorts even though the motherboard is XP compatible, I used it to play the test build of Half-Life yesterday but its main use is working with floppy disks.
Only works offline though, no networking.
Burrito
GE HM1000's
Re: What version of Windows will work on a '02-'03 Intel Pentium 4 « Reply #16 on: October 24, 2024, 08:22:55 PM » Author: Burrito
Mine was made in 2003. The blue screen it gives stays there and I can't press any keys and the HDD stops.
ON LG FOR 2 YEARS! Please don't ask to meet up with me, as I am still living with my mother. Don't send me items either please, thank you!
Please, watch out for the future. It's not looking good. Loves instruction manuals of any kind!
Re: What version of Windows will work on a '02-'03 Intel Pentium 4 « Reply #17 on: October 30, 2024, 03:13:18 AM » Author: RRK
HDD suddenly stopping in fact may be a hardware problem, dry capacitor(s) at power supply outputs causing +5V/+12V rails going out of spec, or having high ripple.
marcopete87
Re: What version of Windows will work on a '02-'03 Intel Pentium 4 « Reply #18 on: November 02, 2024, 05:09:38 PM » Author: marcopete87
Title says it all however, I want to also mention the fact that this PC I'm asking y'all about has Windows XP Home Edition. Will I be able to upgrade it to Vista or
7? Also, not planning on using the PC as a Linux machine.
As far as i can remember, you can have a DDR-1 version or a PC-133 version.
The first, you can upgrade to a max of 4GB of ram (if supported), the second, i doubt.
So, with IDE bus HDD, low RAM capacity and single core processor (with bad performances), it is a triple NO.
Keep XP.
Also, beware of capacitor plague, which was common 20 years ago.
