Dez: the 104B’s have input modules for voltage and current, so can also measure instantaneous power and power quality.
Roman: Ok for a small turbo. See the next set of photos with several visible from the ends, quite small diameter. Pfeiffer TPH series. The Keithley is a DC precision volt meter. Can also be set up to read in Amps if you use an external shunt and measure the volt drop across that. But its not a power meter so cannot measure volts and amps simultaneously.
More photos below: 1: Gas regulators, gas fittings, vacuum valves 2: Turbocontrollers, Turbopumps, KF/NW vac fittings 3: Vac gauges and readouts
« Last Edit: October 18, 2024, 05:50:31 PM by James »
Baked bagel 11
Tom
Can't get anything unfortunatly but I believe I have a 250w son twin arc from that factory!
The classic lights of Canberra are few and far between, this just means that I get know each one better!
Bottled lightning
If any American members want variable ballasts here's a couple https://www.ebay.com/itm/256434332451? https://www.ebay.com/itm/387484802366 Heres the sort of lamps the last one is meant for https://www.ebay.com/itm/354869576884? https://www.ebay.com/itm/225011148266? https://www.ebay.com/itm/144221903968?I think there's a few members here that have 700 or 2000w lamps that would probably want ballasts and the 35w(230v?) and (50hz?) cwa ballasts are probably worth saving. Are there any industrial surplus places around there? I'm assuming the ballasts are mostly 230v 50hz and you probably too busy with the move to deal with shipping tons of stuff internationally? Won't you need the vacuum stuff for led filament lamps? Don't forget to check the attic/basement/closets on the way out. edit; Any of those 3 pin bayonet sockets?
« Last Edit: October 18, 2024, 11:42:48 PM by Bottled lightning »
Hello James, thank you for sharing that stuff with us before it goes in the trash. As you know I am still trying to find a possible date to visit you, it sadly is not as easy as antixipitated.
Is there still a power meter available? If so I would als be interested din one. I am also barticaery interested in HMI lamps 2.5, 4, 6, 12kW especially from Osram, as well as UV sources... Also variable electronic ballast would be very helpful for myself as well as a few G38 Lampholders.
Best regards,
Thanks! Of course I would like also pick some regulators, precision needle valves, vacuum gauges! - stuff very useful with a neon plant. Though logistics is a bit questionable for sure...
GE PM
Ge Post Mount
Collector of all things GE! Except for LEDs. Utility Company: SCE
Michael
James do you have any ballasts left for 40W 2ft tubes? I’m looking for a couple of these. Also for 115W and 140W.
Thanks
GE PM
Ge Post Mount
Have any more been given away? How much is left
Hello a James, I want to thank u for saving most of this stuff in collectors hands.
I be interested in nice Assortment of Miniture HID sockets And 3 pin Socket for MV. I have some lamps but no socket For those pin base HID and some projection lamp use them as well. And any prefocus socket as well. I also have cases of 20 watt mini philips CMH twist in base that look like a T. But no socket for them.
Any Duplicate 35 or 50 watt hi voltage SON lamps would be my great addition
I also wondering if there any custom made chokes to run F32T8. It would be nice compliment for my SLI 32 watt lamps if it was being tested on?
I Live in the US in Texas. For sockets and small lamps should be ok to ship across the pond no problems
No LED gadgets, spins too slowly. Gotta love preheat and MV. let the lights keep my meter spinning.
GE PM
Ge Post Mount
I'm going to bump this. I don't want to see good lights and equipment thrown away. How much is left?
I didn't even see this post when it initially came to exist
~Owen
Scavenger, Urban Explorer, Lighting Enthusiast and Creator of homebrewlamps
GE PM
Ge Post Mount
if not all is saved, could you donate it or auction it off with permission, so this equipment doesn't end up in the trash? also when is the end date?
Zelandeth
Been a while since I've been on here as the lighting hobby has generally had to take a bit of a back seat over the last few years due to a lack of time, mental energy and space.
It is incredibly generous of you to offer this equipment to us collectors like this.
Something that I am very much in the market for at the moment is a proper PC connected spectrometer. I've got one of the little webcam based units which is great for indulging curiosity, but you can't really take *proper* photometric measurements with it. Having mentioned to Dez that I was looking at buying one, he pointed out that this thread existed - and that it really would make sense to see if there was something going in here. I figure that's probably more under the heading of something that you'd be more likely to hold on to as it's not going to stop being useful, but it doesn't hurt to ask I figure!
Emersyn
I have sent this topic to another great lighting collector not on Lighting-Gallery who very well may be interested in some!
If you have any questions regarding fluorescent lamps, feel free to ask me! I will do my best to answer it!
Emersyn
@James Are there any colorimeters, HMI gear, or triple lamp concentric circline ballasts?
