Author Topic: 12V/24V fluorescent ballast  (Read 8228 times)
Milwaukeeman2003
SRX
Fat Squidward Milwaukeeman2003
12V/24V fluorescent ballast « on: September 29, 2024, 03:51:21 PM » Author: Milwaukeeman2003
Hi everyone! I’m looking for a fluorescent ballast that could run on 12/24V to operate on solar power. If anyone can help me, that would be greatly appreciated! Thanks!
Screw the 2028 120 lumen per watt mandate and DeviantArt! Love old cars, cassette tapes, radios, severe weather and most of all, lighting!
Re: 12V/24V fluorescent ballast « Reply #1 on: September 30, 2024, 05:27:01 PM » Author: funkybulb
 Ge did made some Fluorescent  inverter ballast that will run a F30 or F40 T12 tubes  as i have 12 and 48 volt DC ones
 But 48 volt DC is posted in my gallery.
  But U did found a Bodine 12 volt inverter ballast that
Can do the same  on Ebay
https://www.ebay.com/itm/253931007744?_skw=12+volt+inverter+ballast&itmmeta=01J92CNCK6H4RD8PHQQPV0ECCM&hash=item3b1f77af00:g:94YAAOSwapdbwPkg&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKkwPRB1wb2cJZH8wiv%2B%2BWV6bdHS%2FXSUXA8vOjewYyWIzlkHa5UBzVaZE%2FHXJobiBZ2eXdZ5r46WVBsvq2K8WOewtSEInXgaV%2B%2BgPB7FrrtA9jyw%2FtZisXGzHOTLFw8OEcUAJPJMjCV0YnmJxSWvePMTiYYLH3bwFEUjJNpGYewOW2mdPpF4pMjtL%2FuXyKifWdYKZPR%2FWfruiPAICPTl0GM%2BNmxXyyjAQZeZLp4VWl7JvF%2BJ%2BT1SsMOhwazuNpyBaXAARrmI5A7A8ijw%2FmfvSELU0CPPvRgmyN0YjYqIPqJNgg%3D%3D%7Ctkp%3ABFBM1snVzMhk
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #2 on: September 30, 2024, 06:41:22 PM » Author: Milwaukeeman2003
Thanks! But are the lamps mentioned on the ballast still made?
Re: 12V/24V fluorescent ballast « Reply #3 on: October 03, 2024, 05:51:54 AM » Author: funkybulb
 Yes these T12 lamps are still made today,  but imported into the US.   Sadly some states are out right banning them to restrict the freedom of choice.,  just stock up while u can.
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #4 on: October 03, 2024, 12:11:07 PM » Author: Milwaukeeman2003
Thanks for the info! I’ll took into it.
Re: 12V/24V fluorescent ballast « Reply #5 on: October 03, 2024, 08:58:12 PM » Author: wide-lite 1000
 I have a bunch of 12V electronic ballasts for 39W PL-C lamps . The problem is remembering where exactly they are !
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #6 on: October 08, 2024, 02:18:40 PM » Author: Milwaukeeman2003
Sorry for the late reply, but I’m unable to find the specific lamps you’re talking about.
sdsw4
Re: 12V/24V fluorescent ballast « Reply #7 on: October 11, 2024, 02:50:24 AM » Author: sdsw4
I've had success with these "Beasun" germicidal ballasts, 10-17w. Be aware though they're instant-start.
https://www.ebay.com/itm/314900739917
Here's one powering a F17T8 from my gallery. Light output is the same as if I ran it off my preheat.
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #8 on: October 11, 2024, 12:42:22 PM » Author: Milwaukeeman2003
Thanks for showing me! I’ll consider buying one.
Re: 12V/24V fluorescent ballast « Reply #9 on: October 15, 2024, 11:11:54 PM » Author: wide-lite 1000
 These are the tubes I was referring to  https://www.ebay.com/itm/364323918020
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #10 on: October 16, 2024, 02:44:54 PM » Author: Milwaukeeman2003
Sadly, I don’t have any sockets that could accommodate this lamp, but thanks for showing me!
« Last Edit: October 16, 2024, 02:47:24 PM by Milwaukeeman2003 » Logged
Re: 12V/24V fluorescent ballast « Reply #11 on: October 17, 2024, 12:02:28 AM » Author: RRK
You can use a step-up converter to get 120/230VAC from battery and then feed an electronic ballast of your choice. As a rule, electronic ballasts are not picky about input voltage waveform and many can be run even on DC (emergency supply mode).
Milwaukeeman2003
SRX
Re: 12V/24V fluorescent ballast « Reply #12 on: October 17, 2024, 01:26:32 PM » Author: Milwaukeeman2003
Think I’ll go with that! Thanks for the info! BTW, would I be able to use a SOX lamp.
dchen4
Re: 12V/24V fluorescent ballast « Reply #13 on: November 17, 2024, 09:18:39 PM » Author: dchen4
Theoretically low pressure sodium is very similar to Fluorescent lamps in terms of structure and how they behave, but the starting voltage of instant start ballasts maybe insufficient to strike the lamp, modification to the ballast may be needed.
230v Nominal 240v Actual 50Hz
Re: 12V/24V fluorescent ballast « Reply #14 on: January 31, 2025, 04:23:49 AM » Author: WorldwideHIDCollectorUSA
I would be very cautious about using electronic ballasts to run alternative lamps because some members often say that they often underdrive their intended lampa and the current drawn from them is very difficult to measure. I have run SOX low pressure sodium lamps on alternative magnetic ballasts before using imported European market 2 wire parallel SOX low pressure sodium ignitors before. For example, I have gotten 90W SOX low pressure sodium lamps to run very well on a North American 70W M98 pulse start metal halide HX ballast with a Philips SX76 ignitor in parallel with the lamp.
