Author Topic: Why CMH lamps weren't made in 5000K color and above?  (Read 1422 times)
Why CMH lamps weren't made in 5000K color and above? « on: September 04, 2024, 11:05:50 AM » Author: dor123
Why CMH lamps were only made between 2800-4500K and not higher CCT?
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #1 on: September 05, 2024, 03:06:56 AM » Author: dor123
@James?
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #2 on: September 06, 2024, 07:03:07 PM » Author: James
There would be no point.  Even at 4000K it was kind of borderline as to whether or not CMH makes sense.  The primary advantage of ceramic arc tubes is to run with higher wall temperature, so as to vaporise more of the sodium iodide into the plasma and attain lower colour temperature (NaI has very low vapour pressure and is difficult to get enough of it into the arc).  However the other salts that produce higher colour temperatures have much higher vapour pressures and even at the colder wall temperature of quartz, there is more than enough vapour produced.  Conclusion, raising the wall temperature of a high CCT metal halide lamp does not deliver a benefit in efficacy or colour and only causes a decrease in life due to faster corrosion reactions - or requires use of far more expensive ceramic arc tubes than the cheap quartz designs.  So there was no real commercial incentive to develop high CCT CMH lamps.
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #3 on: September 07, 2024, 02:18:46 AM » Author: dor123
So what is the advantage of higher loadings and temperatures of the rare-earths in short-arc MH lamps?
« Last Edit: September 07, 2024, 02:26:07 AM by dor123 » Logged
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #4 on: September 07, 2024, 04:29:19 AM » Author: James
The main advantages are the shorter arc gap for greater optical precision, and under some circumstances a slight increase in red ratio.  The luminous efficacy and even CRI can even be lower, and the life is very greatly reduced.  This is one of the reasons why many daylight metal halide arc tubes are physically larger than warm white types.
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #5 on: September 07, 2024, 05:06:43 AM » Author: dor123
Some 942 colour CMH lamps, have the NaI being replaced by LiI (Like in the case of Philips CDM Lightboost 942 colour). Why is that.
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #6 on: September 07, 2024, 06:03:30 AM » Author: RRK
In fact, Iwasaki offered 5500K ceramic MH lamp. See a screenshot from 2008 catalogue.
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #7 on: September 07, 2024, 06:06:48 AM » Author: RRK
Full catalogue page on these lamps:
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #8 on: September 09, 2024, 05:08:45 AM » Author: dor123
@James?
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #9 on: September 10, 2024, 01:21:04 AM » Author: RRK
Sodium emits in yellow-orange area, sure. So lamps using sodium additive have some excessive orange light causing them to get poor R9 CRI score, because of orange/deep red imbalance. If a lamp designer can manage to get a target CCT without sodium addition, he is just happy to dispose of it.
« Last Edit: September 10, 2024, 02:03:16 AM by RRK » Logged
Re: Why CMH lamps weren't made in 5000K color and above? « Reply #10 on: September 10, 2024, 04:10:00 PM » Author: Medved
I don't think the 4000K has not that much benefit from CMH at all. It depends what is more important for the application, whether just total cost per lumenhour (so quartz wins), or the need for better color rendering (mainly the saturated reds) where the CMH wins.
With higher CCT the difference may get smesred even further (quartz get better color rendering, as well as efficacy), so higher CMH cost won't get justified.
But the "higher cost", as well as "justified" ade very relative terms.
First "CMH" is marketing wise way more "sexier technology", so many, mainly less expert, customers are still willing to spend the premium for it, even if it is not technically founded at all.
Second aspect could be a manufacturer selling just few 5000+K lamps but tons of 3000 and 4000K. Then it does not make much sense to maintain dedicated QMH production machinery for the small volume of the high CCT niche and just design them also as CMH and share the machinery with the lower-CCT CMH mainstream. Of couse, some makers solve this by sourcing niche types externally. But for some brands (mainly those asking premium for being "better than others", e.g. Iwasaki) that may by unacceptable, but also they need to keep the range complete. When already asking higher prices, there is more headroom to use even seemingly not that optimal technology, or even selling those at slight loss just to maintain the product line complete.
