Author Topic: Question about the chemistry of the Osram HCI-TS 70W/830  (Read 1997 times)
Question about the chemistry of the Osram HCI-TS 70W/830 « on: August 31, 2024, 02:28:07 PM » Author: dor123
Why the HCI-TS 70W/830 like most 830 CMH lamps have Dy-Ho-Tm-Tl-Na, while the Osram HQI-TS 70W/WDL Excellence and Philips MHN-TS 70W/730 have Dy-Tl-Na only?
@RRK and @James may know?
« Last Edit: August 31, 2024, 05:48:55 PM by dor123 » Logged
Re: Question about the chemistry of the Osram HCI-TS 70W/830 « Reply #1 on: September 01, 2024, 07:35:36 AM » Author: James
The HCI lamp operates about 200 celsius hotter than the HQI, which increases the halide vapour pressures and causes improved colour rendering - but also shifts the colour point to much lower colour temperature.  A modification of the fill chemistry is required to bring the colour back to the desired point.
Re: Question about the chemistry of the Osram HCI-TS 70W/830 « Reply #2 on: September 01, 2024, 08:24:16 AM » Author: dor123
Ah. But with the 842 QMH and the 942 CMH, the chemistry is the same Dy-Ho-Tm-Tl-Na.
And also @James: Why there are no 5000-6500K CMH lamps?
« Last Edit: September 01, 2024, 11:04:42 AM by dor123 » Logged
