Author Topic: Why are traffic signals different in every state/territory in the US?  (Read 2238 times)
Milwaukeeman2003
SRX
Fat Squidward Milwaukeeman2003
Why are traffic signals different in every state/territory in the US? « on: August 25, 2024, 07:12:35 PM » Author: Milwaukeeman2003
Just want to know why they look/operate differently in different states/territories when in other countries, including Canada, have nearly identical installations throughout their jurisdictions.
« Last Edit: August 25, 2024, 07:19:06 PM by Milwaukeeman2003 » Logged
Screw the 2028 120 lumen per watt mandate and DeviantArt! Love old cars, cassette tapes, radios, severe weather and most of all, lighting!
Baked bagel 11
Tom
Re: Why are traffic signals different in every state/territory in the US? « Reply #1 on: August 26, 2024, 12:43:30 AM » Author: Baked bagel 11
Different DOT standards maybe? In Australia the only difference is whether the target boards are solid black or have a white outline.
Long live the Cobra Heads of America!
Milwaukeeman2003
SRX
Re: Why are traffic signals different in every state/territory in the US? « Reply #2 on: August 26, 2024, 01:11:12 AM » Author: Milwaukeeman2003
That’s what I’m thinking, but I’m not entirely sure. So in your country, the states have little to no authority in terms of traffic light designs?
Baked bagel 11
Tom
Re: Why are traffic signals different in every state/territory in the US? « Reply #3 on: August 26, 2024, 08:24:23 AM » Author: Baked bagel 11
We have only 2 main manufacturers of signals, there are other slight differences but as a general rule the country has similar standards.
Here is an intersection in Victoria.
https://www.google.com/maps/@-37.8395183,144.9956557,3a,15y,322.28h,90.33t/data=!3m7!1e1!3m5!1s_b_85QSGMzPRgWg22kGZTQ!2e0!6shttps:%2F%2Fstreetviewpixels-pa.googleapis.com%2Fv1%2Fthumbnail%3Fpanoid%3D_b_85QSGMzPRgWg22kGZTQ%26cb_client%3Dsearch.revgeo_and_fetch.gps%26w%3D96%26h%3D64%26yaw%3D153.43423%26pitch%3D0%26thumbfov%3D100!7i16384!8i8192?coh=205409&entry=ttu&g_ep=EgoyMDI0MDgyMS4wIKXMDSoASAFQAw%3D%3D
here is an intersection in Canberra
https://www.google.com/maps/@-35.2359471,149.0580235,3a,15y,126.98h,92t/data=!3m7!1e1!3m5!1s2hofykmzrRewn8-yCvvaTQ!2e0!6shttps:%2F%2Fstreetviewpixels-pa.googleapis.com%2Fv1%2Fthumbnail%3Fpanoid%3D2hofykmzrRewn8-yCvvaTQ%26cb_client%3Dsearch.revgeo_and_fetch.gps%26w%3D96%26h%3D64%26yaw%3D293.88797%26pitch%3D0%26thumbfov%3D100!7i16384!8i8192?coh=205409&entry=ttu&g_ep=EgoyMDI0MDgyMS4wIKXMDSoASAFQAw%3D%3D
As you can see, there is very little variation in the SIGNALS, the poles are essentially the same, just different colors.
Re: Why are traffic signals different in every state/territory in the US? « Reply #4 on: August 26, 2024, 08:04:21 PM » Author: joseph_125
In my area, the province dictates the traffic signal standard but the municipalities have a bit of leeway in determining what gets installed.
For example in my province I've seen the following installs:
Yellow signal with yellow backplate - The default signal.
Yellow signal with yellow backplate, grey on the back - used in some municipalities.
Black signal with yellow backpalte - used in some municipalities.
Black signal with black backplate - used in some historical districts.
Milwaukeeman2003
SRX
Re: Why are traffic signals different in every state/territory in the US? « Reply #5 on: August 27, 2024, 02:20:47 AM » Author: Milwaukeeman2003
Works fairly the same way here. But here, the states dictate how the signal is installed, such as my home state banning permanent span wire setups and most of them using black doors, visors and backplates but yellow housings and most don’t have reflectors on the backplates. Some states, like Michigan, use fully yellow signals on span wires, Florida uses span wire signals that span across the intersection and are green in color while Mississippi currently installs fully black signals, poles and masts.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Why are traffic signals different in every state/territory in the US? « Reply #6 on: August 27, 2024, 06:02:22 PM » Author: Foxtronix
Speaking of Canadian traffic signals, even Canada doesn't have uniform traffic signals throughout the country. Quebec (and some parts of Atlantic Canada I believe) is very much into horizontal traffic lights. Oftentimes, though not quite as much as it used to, red lights are also doubled, which is a nice safety feature that should've been adopted continent-wide, IMHO.
Milwaukeeman2003
SRX
Re: Why are traffic signals different in every state/territory in the US? « Reply #7 on: August 27, 2024, 07:21:52 PM » Author: Milwaukeeman2003
Texas often does the same thing for red arrows.
